Set a blade with the Moon sharpener. FAST!!!!!!
Started by ozarkgem, December 05, 2014, 06:39:15 AM
ozarkgem
My blades are 13-9 long. I finally got figured out how to get it in the setter side and got it all lined up and flipped the lever. 1 min 5 seconds to set the blade. Very consistent setting. I was very happy. The belt that drives the stone wheel was missing so I ordered one. 70 bucks for a small belt. I don't have time to chase down another source now and it will probably be the only one I ever buy. Looking forward to the dvd so I can learn the sharpener side. Then I will do a video.
drobertson
sounds fantastic, is there no way to try and sharpen one?  or is there just too much going on?
ozarkgem
Quote from: drobertson on December 05, 2014, 07:03:49 AM
the belt that drives the sharpening stone is gone. Plus there are a lot of adjustments on it. No cam's are involved. All done with 5 different adjusting knobs. I should have the belt and dvd in a few days.
drobertson
Ten four, it sure looks like a nice machine! bet you are pretty happy with this one,  you going into the band blade sharpening biz?
ozarkgem
Quote from: drobertson on December 05, 2014, 07:52:40 AM
I am very happy with it so far. It supports the blade vertical so doesn't take up much room. I have had a local guy wants me to sharpen his blades. We will see. Since I RETIRED I am about 2 yrs behind right now. :D
drobertson
I bet you could set up a few clients for sure, you might even consider being a distributor of bands,  unless you really are enjoying your retirement and don't want or need the hassle.  Looking forward to seeing that thing kick out the blades.
