cold natured honda gx670 on WM(problem solved)
Started by 47sawdust, December 01, 2014, 06:23:52 PM
47sawdust
My 97 LT30 came with a Honda Gx670 on it.It was brand new at time of purchase.I've put about 150 hours on it.It runs excellent until the temp. drops into the 20's.It starts and idles fine,runs normal at full throttle,but dies at the end of the cut when I disengage the clutch.starts back up with no problem.Is their a solution for this other than setting the idle speed higher?
Thanks,Mick
Honda sells a cold weather fan shroud cover for $100.00.It reduces the volume of air to cool the engine.Designed to be used when temps drop below 45°.I cut a 6''disc of 1/4 plywood and zip tied it to the shroud.The honda ran better than ever and thinks it's the 4th of July.
Mick
ely
mine doe sthe same thing until it warms up... seen on here once that it is due to the small jets in the carb made to run in California for emissions. word was you could drill out the jets with a size larger wire drill and it would fix the prob. I never did the work I just keep restarting it. if I bump the throttle a bit right after I finnish the cut it stays running most times.
sprucebunny
I gave up running my sawmill below 40 degrees. Honda engine.
Sure wish you guys would post a picture....
Email it to me and I'll help !!!!
Chuck White
Quote from: 47sawdust on December 04, 2014, 09:11:33 PM
Thanks,Mick
My new 25hp Kohler does the same thing.
Noticed it on the last sawjob when temps were from 20°-40°F.
I was thinking of ziptying a piece of cardboard or a thin piece of wood over 1/2 of the air inlet on the front of the engine, but the job only lasted 4 days.
Corley5
My firewood processor is on its 2nd 670.  They've both ran well at temps in the single digits.  Where they've both had issues is in temps between about 33 and 37 degrees with some humidity.  The carb will ice.  You can look in the top and see the frost on the outside of it.  It's the frost in the carb's throat that causes the problems.  The engine will be begin to run erratically and the governor won't do what it should.  Shutting down for a few minutes to let the engine's heat thaw things out helps for while  ;)  In this application the engines runs full throttle all the time.
sawguy21
Carb icing is a headache, a little creative duct work will direct exhaust heat to reduce he problem. In cold weather pull the breather tube off the air filter base and let it hang, cover the hole in the base with duct tape. If normally hooked up, ice will form in the hose and the crankcase will build pressure which will lead to oil consumtion and possible popped crank shaft seals.
loghorse
I bought a landpide treker,like a jd gator.Has a 20 hp honda .previous owner blocked off half the shroud to run better.Also came with a pipe cut in half lengthwise that goes over the exhaust pipe right at ihe block.other end of half pipe is full round pipe that accepts the hose   going to aircleaner.put it on 2 weeks ago at 0 F ,when warmed up it purs like a kitten.Not computer savy or would post a pic. Can be bought as optoin from honda
FarmingSawyer
Quote from: sprucebunny on December 05, 2014, 07:10:25 PM
Anyone got a photo of this mod?? I tried running my gx630 this AM at 12˚....and it worked but kept cutting out after the cut. Wouldn't warm up. Too cold to be milling anyway as my finger's froze, but I've got to get back at it once it warms up to 20˚.......
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
sprucebunny
I'm guessing they just put a piece of cardboard over the round vent on the front side of the engine. Carb is buried in behind it.
FarmingSawyer
So I did this and was able to run the engine pretty much trouble free for a long time at 16˚F...... And I could close the choke all the way......
47sawdust
Don't be afraid to try a larger disc,the one that honda sells closes off almost all the air.
Mick
Mick
FarmingSawyer
Quote from: 47sawdust on January 01, 2015, 05:55:06 PM
Mick
I kinda wondered if 6" was gonna be too small....but it seemed to work like a charm. I still have rags stuffed in the air-inlets as well......
