Size for saw dust blower
Started by Brad_bb, November 29, 2014, 07:15:36 PM
Brad_bb
Having my new mill inside and having an MP100 planing head as well, I'd like to look into dust collection.  Rather just getting the dust outside in a bin or pile.  I have 220V single phase available.  I'll only be exhausting one machine at a time.  How much CFM do I need?  HP?  Can I do it with single phase?  Any specific recommendations?  I was watching one youtube vid where a sawyer mentions having a Cincinnati 1.5 hp blower.  I found one under that name on ebay, but now sure if that is what they are using.  It has a Baldor motor and aluminum housing on the blower.
Brad_bb
Some of you guys out there must be extracting dust with a blower into a bin outside?
drobertson
There are some threads on this, not sure how far back but quite a few,, single phase just cost more to run, and I am thinking 2hp might be the minimum. It depends so much on the length of the run and header, elbows and gates,  and a few more items,
dblair
there's a lot of information out on the internet about this . I looked this up and found it interesting .
http://www.billpentz.com/woodworking/cyclone/staticcalc_faqs.cfm
old Appomattox Iron Works circle mill.
Chuck White
Look in some of the members galleries.
There are some who have sawdust blowers hooked up to their LT-40's that actually pipe the sawdust into huge piles, some distance from the sawshed!
pineywoods
Quote from: Chuck White on December 04, 2014, 10:02:29 AM
Guilty.. 8)  Here's mine.
You will find that hooking a blower to a bandmill will require more than a little backyard engineering. Flex hose won't last very long and it's pricey.
The blower is a 2 hp single phase unit from a harbor freight shop dust collector. 5 inch inlet and outlet. The metal pipe is hardware store six inch stove pipe..There's 3 homemade swivel joints in the inlet pipe, one on the blower, one in the middle and one on the mill head. This setup not only gets rid of the the sawdust, it also gets all the pieces and parts above head height, out of the way..
If you go this route, be prepared to replace the on/off switch on the harbor freight blower.
blade69001
Quote from: pineywoods on December 04, 2014, 02:40:48 PM
Good to know about the HF dc blowers I run three of them, two in a tandem set up that allows me to run my resaw constantly without having to change collection bags.
Sean P.
Just being me, But it is ok you do not have to like me.
Foxtrapper
I will be moving the lt28 into a shed of some sort in the next few months.  Have thought long and hard about hooking up a blower to remove the sawdust.  But, i'm not to keen on having more stuff to walk around and trip over, so i'm not sure how I want to do this.  I have thought of making a conveyor to remove it with, but I dunno, maybe more pain than it's worth.  Of course I also have 3 helpers who can do the job with a shovel and wheelbarrow if needed... 8)
2014 WoodMizer LT28
Glenn1
Pineywoods, are you using a single blower?  What do you estimate your total run to be?
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
pineywoods
Quote from: Glenn1 on December 04, 2014, 09:29:28 PM
Yes, a single blower. There's about 15 feet with 4 elbows on the intake side, leading to the blower, which is mounted under the rafters about 8 feet up. The output side is a straight pipe about 20 feet, so a total of about 35 feet. . Large chunks of pine bark and stringy cedar bark will occasionally plug up the screen on the intake of the blower. I left the screen in place, better to plug up there where it's easy to get to than inside the blower. Otherwise, it handles everything the lt40 can throw at it.
YellowHammer
Here's mine. Very simple, no maintenance, and between the mill and the planer I normally fill the 3 cubic yard trailer most every weekend.  Makes the sawdust problem just about become a bad memory. The key to a long life system is to have a swivel of some kind on the inlet side so that the saw traversing back and forth doesn't kink or stress the plastic dust hose.  I'm using a basic 110V stand alone dust collector blower.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
barbender
Wow YH! Some of that sawdust actually looks like it landed in the trailer!  ;) ;D
Dave Shepard
Below is the system that I rigged up at the mill I learned to saw on. It collects from the egder and planer as well. The piping for the mill is 4", and I made my own swivel out of a gasketed SDR fitting with the rubber gasket pulled out. You can see a spring that goes between the green pipe and the white fitting. The spring keeps it together, and keeps it centered somewhat. Not only does dust collection save a lot of shoveling, but it also cuts way down on the airborne dust. It was really awful to saw red oak in there before the vac was installed, but after, you could hardly see any dust in the air at all.
drobertson
Dave, that looks to be a serious blower!  nice!
Peter Drouin
Quote from: Dave Shepard on December 05, 2014, 11:51:59 AM
Does it freeze up in the winter?
A&P saw Mill LLC.
License NH softwood grader.
Dave Shepard
We never had any problems with freezing. Sometimes, if you were sawing really fresh pine, it would clog a little in the flexible pipe. After the building was built where the blower is, they did some really stupid piping to get to the trailer. The had a 180 turn on top of the blower going down into the slab, and a 90 there going out to the trailer. I would have gone through the roof and put a 90 then straight to the trailer. Also, they put a 7.5 hp electric motor on it, and it really wanted at least a 10, if not a 15 hp. It never worked as well after they did all that to it.
YellowHammer
Quote from: barbender on December 04, 2014, 10:15:17 PM
:D :D When the wind is blowing hard, it never even gets close to the trailer. :D But the wind wasn't much of a factor here, this was just a "close is good enough" ;D
I used to just let the sawdust fly onto the ground and let it pile high up to the discharge chute.  For some reason I never had time to pick it up and it would just get out of control. You can still see the outline of the dead grass that got nuked by the old sawdust pile. It isn't even trying to grow back after a couple years.  Now I just pick the whole trailer up with the forks and dump it like a bucket prior to a day's sawing.
YH
YellowHammerisms:
