Skyline for super low impact (don't laugh west coast folks)
Started by dustintheblood, November 27, 2014, 11:14:11 PM
thenorthman
that snatch block trick is skookum! like a poor mans christy carriage... I may have to steel it...
So I take it yer just hand dragging the line back out?
well that didn't work
dustintheblood
Was going to hitch up the border collie named "Chunk" with a harness and rope to draw it back down to me, but then my helper had the picture of the dog hanging 12' up in the air.
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
Ljohnsaw
Pretty neat.  Thanks for posting.  I like the way you used the snatch block to pick the logs up then fly.
John Sawicky
loggah
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
chester_tree _farmah
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
treeslayer2003
i like it! it gives me ideas lol. i passed up a job like that a few years ago.....white cedar.....not even sure where i'd have sold them.
it still amazes me what small cable will take.........i'm so used to 3/4.
dustintheblood
Dagnabit, no one noticed me drop the stem about 6" from the camera (yeah on purpose).  Guess it comes with being here with a bunch of pros.   :D :D :D
treeslayer2003
Quote from: dustintheblood on November 28, 2014, 10:16:10 PM
i seen it
dustintheblood
If I still had my hat on it treeslayer, I'd tip it toward yah
treeslayer2003
what size cable is that? and how is the market for that stuff? wouldn't want to do that for just tie logs.......
dustintheblood
Cable's the rolled heavy 1/2" - more than enough for cedar the way we're hauling.  I'd be thinking twice before tying onto a big chunk of white oak.  Thing is that with the skyline, I need it for the wet areas.  When it comes to the hardwoods here, winter's coming - easy skidding and I'm not afraid to pull line way out, and grab a snatch to get around stuff.
Markets?  Well back in the day I could name my price.  For now, I'm sawing it, drying, planing it and making a big a___ pile of it.   Shoooooot.  Markets are just squirrely.  I know they'll come back but for now I'm working toward being a guest star on discovery channel's  "hoarders show".   :D :D
I've also got a 40x80 timber frame barn that needs new siding, so the 8" stock's got a good home.
Skidder Kev
Looks like a pretty nice set-up you have there.  thats some nice looking cedar you have there too.  Where abouts in Ontario are you?
CCC4
Pretty cool! What do you figure the longest pull you could make would be?
Offthebeatenpath
Great video and great work! It looks pretty efficient to me for a small scale skyline operation without a yarder.  I have done this a bunch, but I usually use two power sources- one to lift the skyline wire and one to pull the load along the line.  Am I correct in seeing that you are using only one?
1985 JD 440D, ASV tracked skid steer w/ winch, Fecon grapple, & various attachments, Hitachi CG-30 tracked dump truck, CanyCom S25 crawler carrier, Volvo EC35C mini-ex, Kubota 018-4 mini-ex, Cormidi 100 self loading tracked dumper, various other little trail building machines and tools...
dustintheblood
kculler - we're near Kingston, and yeppers, the cedar's pretty good around here.  This site was blowdown in a pocket of mid sized stuff, so the quality's not as good as what's waiting for me in that swamp this winter.
ccc4 - I'm thinking 200 feet horizontal is about all the cable sag will allow.  Any further on flat terrain, I just won't get the lift on big logs
offthebeaten - yep only using one powered 3-pt winch to pull the lower line.  When I'm setting up, I use the winch to pull the skyline tight, and then ratchet it down to secure it
Offthebeatenpath
Dustintheblood-
That makes sense for use with one power source.  You definitely would gain efficiency with a second, but then again, you are doing very well with what you have.  A capstan winch can work well to pull a suspended load uphill.
CCC4- As I understand it, skyline system length is limited ultimately by the curvature of the earth.  Theoretically, if you can get your spar blocks high enough in the air relative to the terrain, They can be 400, 600, 1400 feet long.  A basic rule is keeping 10% deflection (the same amount of sag you see in suspension bridge cables), so a 300 foot long skyline should have 30 feet of deflection, or sag in the skyline wire after the load clears the ground.  Less sag means more more tension on your anchors and power source, but more sag means more tension on your spars.
I'll post a couple photos of skyline systems that I have set up in a bit...
FarmingSawyer
Awesome work. I wanted to rig up something like that years ago to fetch shake bolts out of a swamp...... I think this would work well for an area of cedar I have to harvest now.
What sort of snatch block are you using on the high line? Do you have a picture of how you secure the ends? Thanks.
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
dustintheblood
I'll try and take some better pics today, and post them up.
Offthebeatenpath
Here are a few semi-related rigging sets that I have played with.  I use mostly hand powered winches because they are in remote settings inaccessible to machinery.  These are not production logging systems, rather super low impact ways to move materials around for backcountry construction projects.  That said, we have moved hundreds of loads on a single set before and I have started using the winches on my skidder and skid steer in these systems.
Here a a couple illustrations that my fiancé drew of other rigging sets that we've used in the past. The first is a running skyline and the second is a double highlead with double haulback lines.
thenorthman
A true yarder is limited only by how much cable it can carry, or how good the anchor stumps are, the farther out you go the thicker the cable needs to be so the bigger the winch drum has to be... its a catch 22 thing. There is also the use of intermediary supports, allowing work on slopes that are not ideal.
Then you get into the 3 drum yarders that have the ability to drag the carriage uphill, allowing us to pull logs up and down hill, from one setting, or in most cases where building road to the top is out of the question for whatever reason....
anyway heres a vid
http://www.youtube.com/watch?v=ET64XzbUYiY
CCC4
I got to visit a yarding operation when I was out in NoCal...I took tons of pics of it but I have about given up on posting pics here...I can't figure out what all I am doing wrong...go figure.  :o
CCC4
Quote from: thenorthman on November 29, 2014, 10:32:47 AM
anyway heres a vid
[/quote
OMG thats impressive NM!
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
dustintheblood
Thanks to everyone who added posts to this.  I can't wait for more freezeup now so that I can get in and really put the thing to work - with more improvements!
