Pine boards
Started by Banjo picker, November 24, 2014, 10:45:00 PM
Banjo picker
Picked up two loads of logs for one of the local vets. There were some pretty nice pine logs in them. Supposed to use them for siding, and wanted some wide ones...I like that.
I am thankful for those roller tables.
Chuck White
Real nice boards there, Banjo!
WmFritz
That siding installation ought to go quick!
Nice looking lumber.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
slider
What kind of truck is that at the end of the mill Banjo it looks old.
al glenn
caveman
Nice, wide pine boards.  Is that a Willy's parked behind the drill press?  Caveman
Caveman
drobertson
Nice job,  no doubt that the wide ones cover ground quickly! 8)
Love them wide boards Tim.  B&B or Shiplap?
Banjo picker
From the other buildings he has around , I think he will put them up as B &B.  He is a fairly regular customer, I have know for a long time.  The ole rides at the end of the mill are indeed Willys.. The one on the right is a 1960 wagon and the one on the left is a 1964.  The 1960 runs and is going to the garage bay at the house probably tomorrow for some attention.  I also have an early 50's pick up in another building but it has a stuck motor.  Glad you liked the picts.  Banjo
dboyt
A sawmill, a couple of old trucks & a banjo.  Sounds like the good life.  Thanks for sharing.
Howdy
Saw the Willys wagon right off 'cause I have a '53 myself.
Nice to see one being used, and good looking wood too.
customsawyer
I like it all. The boards, the truck, the drill press and the mill. ;D
www.thecustomsawyer.com
Banjo picker
Thanks for the replys. They came to get the lumber yesterday.  I loaded 4 bundles on the wagon they brought, loaned them two ratchet straps, and then hooked a chain to the back of the trailer and hooked it to my tractor as they went down the hill...no brakes on the trailer.  They have another load to pick up as well.  They had a couple of mickey mouse ratchet straps, but they were not even long enough to go over the load.  I had a dozer push me off the road going down the drive on a trailer when pulling it with the 3500 ram, so I am a little paranoid ... My employee in the truck said.."Its coming after us". But I had the truck in 4 wheel dirve low and couldn't get out of the way fast enough.  Didn't want that to happen to the truck they were in.  Have to take care of your customers, esp. repeat ones.  Banjo
Meadows Miller
G'day
Looking good and X2 on Jakes comment  Tim splitwood_smiley digin_2 ;D ;D 8) 8)
Regards Chris
4TH Generation Timbergetter
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Banjo picker
Thanks for the kind words guys.  I guess I started hoarding the willys since you were here Chris.... ;)  Jake and the rest of you'll that like willys should look at Electric Als u tube stuff. He has a video of a sharp willys pickup on it.  He told me it was a customers...If I can get mine looking anywhere that good I will use it as an advertising piece...leave a few board in the back of it while driving it around.... :)  Banjo
Meadows Miller
G'day
You must have Mate ;)  :) I love em and saw the one on ALs y-tube page very nice  :o ;D very rare in aus but where popular down here in their day :)
Chris
