you might be a bachelor if you------
Started by ozarkgem, November 22, 2014, 08:57:10 PM
POSTON WIDEHEAD
Quote from: SawyerBrown on November 23, 2014, 06:15:15 PM
You might be a bachelor if you ... don't come up with the right answer to your wife's question, "Does this dress make me look fat?"
Just say NO......But the DanG cheeseburgers you keep woofing down does.  smiley_horserider
r.man
You would want to be one fast goat to outrun a flying object. I knew a fellow who drove his snowblower through the house rather than go the long way around. He was also the one who tethered himself to his 4 wheeler winch to swim in the river with a life jacket on. When you think about it our parents were the original nay sayers of " I think I will do this ". When a man doesn't have a woman around all sorts of things start to seem reasonable.
Gary_C
... are bachelor brothers that believe it's OK to bring the portable rubber fingered chicken plucker right into the kitchen in the winter to butcher the chickens and yes, it does leave feathers stuck to the wall and ceiling.  :o
Also if you believe the wood stove in the kitchen is a good place to heat manure spreader shafts to get bad bearings off.
Yes, they live just a few miles from me and yes, they are still bachelors.  :D
redprospector
If you've ever put a new jug & piston in your chainsaw using the dining room table as a work bench...and then fired it up to make sure it would run.
It was really cold outside.  :D
kensfarm
Your vacuum of choice is a 16 gal shop-vac. ;D  That it works like a leaf blower is an added cleaning option!
sandhills
Quote from: Peter Drouin on November 23, 2014, 07:16:58 PM
How about cutting up a steer on the dining room table :D :D
Now what could be possibly wrong with that, he's going to be a steak anyway  ???  ;D
coxy
my dad was a good one for doing most of what has been said  and they say the apple don't fall from the tree  :D just ask my wife she has been trying to train me for 20 years  i have been told a lot i am a sloooow learner  :)
trapper
my wife helps me cut up deer on the kitchen table.
kevin19343
You might be a bachelor if you use the turkey baster to remove brake fluid from the reservoir when replacing the pads.....then spray it off and put it back in the drawer where you found it.
SawyerBrown
Quote from: kevin19343 on November 24, 2014, 04:38:30 PM
You might be a bachelor if you use the turkey baster to removing brake fluid from the reservoir when replacing the pads.....then spray it off and put it back in the drawer where you found it.
:D :D :D
bobby s
I might become a bachelor if my wife finds out I use her good Pyrex measuring cups to get that chainsaw premix just right.
POSTON WIDEHEAD
Quote from: bobby s on November 26, 2014, 08:09:13 AM
:D :D :D
SawyerBrown
You might be a bachelor if you ... have a two-bedroom apartment, and use one of the bedrooms for your woodworking shop.
And, yes, I know a guy ...  Says he keeps that door closed when the landlord comes around ....
Raider Bill
Do a total rebuild of a Harley in the dining room, soak the parts in (spare) bathtub and minor assembly on kitchen counter top..
Delawhere Jack
Quote from: luvmexfood on November 23, 2014, 03:15:33 PM
You have a load of laundry washed and dried that really needs to be folded or hung up that day. You put them on your bed so that they have to go up before you can go to bed.
They just end up on the floor, or back in the basket....... ::)
Delawhere Jack
Quote from: Raider Bill on November 26, 2014, 09:58:31 AM
Greasy transmission housing in the utility sink in the basement...... What, it fit.
Peter Drouin
Through the peanut shells on the floor.
A&P saw Mill LLC.
License NH softwood grader.
timberlinetree
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Don_Papenburg
That's funny , a friend acquired a fire truck for a "yard ornament ", and got a lot of grief when his wife got home . The next day the local fire department parked two of their older trucks beside his just before his wife came home.
sawguy21
That is a regular occurrence here. She piles them on the bed, I put them away so we can go to bed. ;D
iceman7668
You might be a bachelor if you use the dryer as a dresser. Just run it a minute or two to get the wrinkles out before putting your shirt on.
John D Myers
goose63
  the wife dont mind she helps cut deer all the time but the chain saws stay in the shop
goose
thank you to all the vets
Chuck White
Man, that looks like a heavyduty grinder you have there, Goose.
Probably ground a lot of meat with it.
Be careful.
ozarkgem
now that is the way to grind meat. Next step up would be a diesel powerplant.
goose63
Chuck that grinder is bout 60 years old ground a lot of meat
ozarkjem the diesel plant is out the wife put her FOOT down
goose
