How to make this cut????
Started by POSTON WIDEHEAD, November 15, 2014, 11:52:54 AM
POSTON WIDEHEAD
They've started selling these small bonfire logs in my area.
The log looks like Birch.
I can't figure how they made the star cut into the log. Its not with a chainsaw, its to perfect.
However they did it, this is a hot item right now and these small bonfire logs are selling!
LaneC
How deep are they? It looks like probably a morticer may have done it, or maybe a router.
Man makes plans and God smiles
LaneC
Maybe even just setting a skil saw down on the log. With that wide of a cut, they may have a shim under the blade to make it wobble and give a bigger cut.
POSTON WIDEHEAD
The cut goes down about 1/3 of the way.
I'm pretty sure I can do it with a chainsaw but these cuts look perfect.
fishpharmer
I looked at the website for more info.  Nothing about manufacturing.  Amazingly, its patent pending.  A log with a unique sawcut say_what materhead
http://essay-group.com/products-page/ecoforest/light-n-go-bonfire-log-2/
http://youtu.be/FwsZMHRzTW0
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
POSTON WIDEHEAD
Watching your video, I'm wondering if the center has been soaked in some type of oil?
fishpharmer
May just have some wax poured in the cuts.
Dave Shepard
I looked at those recently. The one I looked at it was a chainsaw cut, but I'm sure it was machine guided. I think those are originally known as Swedish candles, and have been around a long time. You can make your own in a few seconds with a chainsaw. Normally, the cuts would go down the sides almost to the bottom. Some wax or other fuel is often poured in the middle to get it burning.
Maybe a good technique to try for burning out stumps.
Depth a third of the way, would put them at about 4" ??
Get one and split it open so we can see the bottom of the cut and how it may have been made.  ;)
If I was going to make a heap I'd be mating up an electric chainsaw and a drill press, with a rotating table to clamp and index the log.
LaneC
I would bet on a morticer machine they use for mortises in timberframing. Makita makes them as well as others. They are pretty pricey.
LaneC
Go to you tube and type in" chain mortise tips" Jim Rodgers has a video of using one. I know it is on a beam, but you could probably keep turning it.
POSTON WIDEHEAD
Quote from: Ianab on November 15, 2014, 02:56:32 PM
I thought about that Ian.....but would the chain still kick?
roghair
As Dave says, these are Swedish candles. There is no need to cut them like that, you can cut down over the whole radius. They are very popular here in The Netherlands and sell for about $ 5 (60 for $ 300  :) ) I saw them as little presents and use red pine with a lot of resin. The jig I made works OK, but needs some modification in grabbing the log with the spikes.
built a sawmill
POSTON WIDEHEAD
Roghair, do you put any kind of burning oil in the cracks?
Would it be easier to saw the grooves while its still a log and after the grooves are sawn, saw off a 16" length or whatever short log?
red
Dave I have a special tool for you
Today's Special $300
POSTON WIDEHEAD
roghair
Quote from: POSTONLT40HD on November 15, 2014, 05:12:57 PM
I drill a hole for a firelighter, most of the time that works fine. The grooves give a good ventilation (venturi), which might be less with the cut you were asking for in your OP. They probably use some kind of oil.
I am not very good with the CS, so for me it would be more difficult making these cuts in an horizontal log. As you can see in the picture, cutting it square from the log is also a challenge...
built a sawmill
Buck
Another name I've seen is Stump Stove. As I recall the cuts were criss crossed and a hole for air flow bored in the bottom.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Brad_bb
Maybe they used a morticer with a slotting chain attachment?
POSTON WIDEHEAD
First time I've seen one of these Brad. Of course I've never seen a sow blower.  :D
Thanks of the pic. I think this is what Ian may have been talking about.
terrifictimbersllc
Quote from: POSTONLT40HD on November 16, 2014, 02:30:16 PM
Don't  think I have either, in spite of a fair amount of time on the farm,  what is it?
customsawyer
That thing would have to have a hog of a motor on it.
www.thecustomsawyer.com
POSTON WIDEHEAD
Quote from: customsawyer on November 16, 2014, 04:38:54 PM
Y'all can kiss my Grits...all ya had to say was I misspelled "snow".....but NO.....
ya got a go and Pig Out on me!  >:(
Peter Drouin
Quote from: POSTONLT40HD on November 16, 2014, 08:16:04 PM
:D :D :D :D :D :snowman: popcorn_smiley
A&P saw Mill LLC.
License NH softwood grader.
