Sharpen then set or set then sharpen?
Started by golddredger, October 29, 2014, 01:13:33 AM
golddredger
What have you guys that do your own blades found best? Sharpen then set after or set then sharpen? And if you could explain why that would be very helpful. Thanks
Home built bandsaw mill and trailer for a mini logging operation. Lots of chainsaws and love the woods.
terrifictimbersllc
Setting first eliminates having to de-burr the blade.  The burr resulting from sharpening interferes with the setting process, as it interferes with measuring set.
36 coupe
If you set after sharpening the tooth face is no longer at 90 degrees.It takes on a negative angle.Not good for cutting wood.The tip of the tooth does the cutting.
Banjo picker
That's the two reasons I set then sharpen.  Besides Tom told me it was best to do it that way...no need to question why.  Banjo
Chuck White
Set first, then sharpen, less hastle and less time!
This way you will be cutting with the entire "chisel part" of the tooth.
golddredger
Perfect! Thanks now back to blade prepping! 8)
Ga Mtn Man
Quote from: terrifictimbersllc on October 29, 2014, 05:40:36 AM
So de-burring the blade isn't necessary?  I've been wondering if it makes any difference.
customsawyer
I sharpen then set. Keep in mind that I push my blades further than most so my tips are so rounded that I can't get a accurate set if I do that first. I don't deburr my blades I set the setter up on zero with the burr on the blade. When the lumber knocks the burr off all is the same. ;)
www.thecustomsawyer.com
Nomad
Quote from: Ga Mtn Man on October 29, 2014, 08:33:06 PM
     Not a bit.  First or second time that blade goes through the wood, any burr is long gone.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
terrifictimbersllc
Set, sharpen (now there is a burr), then saw with the blade, it is gone in an instant.
Sharpen, there is a burr.  Set (including measuring the set), there is a 1-2 thousandths burr that bugs me.  When I did it in this order, I would pull the blade over a piece of hardwood which would remove the burr.
I think the other point 36 coupe brought up is more important.
But it probably doesn't make much difference, as I've done it the other way and so do others.  I think set, sharpen is a bit easier.
woodmills1
The last few years I just push the blades.  They are so good now I get nearly a thousand feet in soft wood, then sharpen and do another thousand  in hard or soft.
I HATE TO SET
YellowHammer
I set then sharpen most of the time, but for the bands that I push in real hard wood, or when I can really see a dull or rounded tooth tip, I usually sharpen, deburr, then set, because as CustomSawyer has said, setting on a dull tooth can be inaccurate.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
pineywoods
I norrmally set first and then sharpen, but there is one case where I sharpen first. I do some sharpening for other sawyers and once in a while get a blade that some DIY type has ground off just the face of the tooth so much that there is only a nub of a tooth left. May take as many as half a dozen passes around the sharpener to get the teeth back to shape before setting and then sharpening again...I do find that sharpening and then increasing the set a bunch does result in a band that does not cut as well in some types of wood, cypress in particular...
