Narrow Kerf Chains and Bars
Started by CaptainBigWood, October 14, 2014, 05:47:30 AM
CaptainBigWood
I am running a Stilh 026.
Looking at a narrow kerf Stilh PS3 chain 3/8 .050 for a 20" bar.
What size sprocket is best?
Also considering upgrading the clutch to a rim sprocket.
Any thoughts on this combination?
mad murdock
You will like the switch. I run narrow kerf on my medium sized saws, really helps keep the cutting speed up when the bar is buried. I like them.
webgal
Though you can use picco on longer bars for cutting, I've heard that the chassis is a bit weak and they are prone to break in conventional cutting after 20".
If you do want to try narrow kerf without the sprocket change there is .325 narrow kerf chain. You'll get the sturdy chassis, conventional chain lengths and narrow kerf performance. You'll need a narrow kerf bar to suit to take advantage of that nicer slice.
Just another option.
Gotta know when to fell em, know when to tell em, know when to walk away, know when to run....
HolmenTree
Quote from: CaptainBigWood on October 14, 2014, 05:47:30 AM
3/8 -7T Picco rim part # 0000 642 1240 at your Stihl dealer.
024/026  rim sprocket drum kit with 7T  picco rim # 1121 007 1004
If the Stihl kit# doesn't work then order a Oregon drum kit for a 024/026 from our sponsors Bailey's.  They won't have the Picco rim though.
The 0000 642 1240 Picco rim is available through your Stihl dealer though. While there ask about the Picco guide bar available for the MS241CM which has the 63PS chisel chain setup as an option which is available here in Canada. Not sure about the U.S.
DR Buck
Quote from: HolmenTree on October 14, 2014, 09:25:30 AM
Bailey's hasn't been a sponsor for a while now.
CaptainBigWood
Thank you for the great information, including part numbers.
On a standard 3/8 .50 chain 20" bar is takes 72 drive links.
Since the gauge is the same, would the narrow kerf would also be 72?
Thank you for the education.
HolmenTree
Quote from: CaptainBigWood on October 14, 2014, 08:01:24 PM
Yes 72 Picco drive link chain on a standard 3/8 20" bar .
My first question is do you already have a 20" 3/8 bar on your 026?
SawTroll
Yes, if it was equally long and had abiut the same profile - but be aware that stated bar lengths are just nominal, and often quite a bit off......
Information collector.
mesquite buckeye
One small comment. I like the narrow kerf bars with one caveat. They bend easy. If you get your saw stuck regularly and have to yank it out of a cut, such as in limbing or just pinchy, hard to judge lean in a thinning deal, treat them with kid gloves.
In any work where the cutting is predicatable and binding is minimal, they cut faster with less power needed.
Just sayin' ;D 8) 8) 8) :snowball:
HolmenTree
Yes, you have to be careful with that NK stuff especially when you go over 16"b/c.
I've had good luck over the years with the .325 NK semi chisel Oregons and Carltons on my smaller saws up to 18". But the OP C.B.W. of this thread is looking at 20" with the little Picco chisel chain which I think he'll have a hard time finding a 3/8 Picco sprocket tip bar in that length .
Stihl has introduced the MS241CM with a 18" Picco setup but I believe that's as long as they go.
I do have a good supply of 16" Windsor/Sandvik Mini Pro bars with .325 and 3/8 LoPro [Picco pitch] replaceable noses, even have a few 1/4" and standard 3/8 noses too for them.
But the bars are fairly thick so when the little 1/4" or Picco chain is filed down to half sized cutters or less there's a lot more chance of pinching with that reduced kerf related to the thickness of the bar.
Here's a pic of the little 3/8" Picco chisel chain that everyone wants, I have it comparing up to the .325 NK semi chisel chain. Last pic is my 550XP with one of my vintage 1980's Mini Pro bars.
HolmenTree
Here's one more Stihl 63PS pic at a different angle with the Husky .325 NK.
HolmenTree
.................OOPs something happened here ??? got posted before I hit post button
HolmenTree
Here I'll try again  :D
This chain I won't recommend for the OP's 026 but works just fine on a wee little MS150 or battery saw.
Here's another pic of a Stihl "mother of invention" sawchain.....the 71 PM3.
It's another  Picco chain but in 1/4" extended pitch. Without the extended cutter the cutter bit would be of about 1/8" pitch equivalent   or less......tiny little chain, another 1st for the industry.
webgal
Holmen mentioned finding a 20" bar suitable for low profile would be tricky. Cannon advertises one. They are certainly a rare item though. Hence my .325 narrow kerf option to keep things more standard.
http://www.baileysonline.com/Chainsaw-Bars/Professional-Replaceable-Sprocket-Nose-Guide-Bars/Cannon-RSN-Guide-Bars/Cannon-Super-Mini-Guide-Bars/Cannon-20-SuperMini-Chainsaw-Bar-for-Stihl-72-Drive-Links-CSM-S1-20-50-3LM.axd
HolmenTree
Quote from: webgal on October 15, 2014, 09:15:19 PM
Thanks for finding that and posting it for us Caprice! We now have to look no further.
Very important to run a 3/8 LoPro chain on a bar with the same pitch in the nose along with the drive sprocket.
Here's my Cannon Super Mini bar I bought off you guys at Bailey's a few years back, outfitted on my 562XP. It's a 18" standard 3/8" pitch bar, one of the best bars I've  ever run.
It looks like Cannon took over the design of the discontinued Windsor/Sandvik Mini Pro bars that I showed earlier of the ones I own. Both of these bar's sprocket replaceable tips interchange.
HolmenTree
To add to my last post this chain is a standard 3/8" pitch chisel chain called a Oregon 76LG .050
This chain was discontinued about 20 years or so ago. Looks more like a .325 but is an actual standard 3/8 chain.
Beautiful smooth cutting chain.
HolmenTree
A photo here of my 2 Husqvarna's comparing Cannon's copy of the old discontinued Windsor/Sandvik Mini Pro bars. Both noses interchange, only difference is the Cannon's nose is slightly longer for better wear durability.
I really like the way Oregon 95vp chain cuts, on my 346xp Husky. However, the bars don't hold up for me. The sprocket tips invariably let go, usually after only running 2 or 3 chains. Holmen, I really like the look of those Super mini bars.
SawTroll
Quote from: HolmenTree on October 15, 2014, 09:34:00 PM
Oregon 76/77 has low profile cutters on a standard size 3/8" chassis, like the Oregon 33/34/35 in .325 and Stihl Topic in both pitches. Most of those models are discontinued.
Does that bar have a 9 t nose?
HolmenTree
Quote from: barbender on October 18, 2014, 09:22:24 AM
Yes these Cannon bars are a superior bar, they definitely improved the quality over the old Mini Pro bars. Like pointed out earlier every pitch of sprocket under .404 is available for them just like the old Mini Pros.
HolmenTree
Quote from: SawTroll on October 18, 2014, 09:43:37 AM
Standard .375 (3/8) sprocket nose Niko.
HolmenTree
Here's a pic of the long ago discontinued Stihl 33TS (Topic Super) compared to the full sized 33RSF. Being close to the camera's  lens makes it look bigger then it is.
Stihl would be wise to reintroduce it.
HolmenTree
Niko, my eye sight must be going. I re-read that question you asked me about that Cannon bar.
I thought you said 91 nose (Oregon 91 pitch chain).Now I see the t :D
Yes the nose is a 9 tooth  sprocket tip.
brettl
I've been thinking of this for my 024s. Is the Stihl Picco rim compatible with the Oregon drum? Can a standard 3/8 Oregion rim be used with Picco chain?
HolmenTree
Quote from: brettl on October 19, 2014, 09:07:33 AM
brettl, yes the Stihl Picco rim is compatible with the Oregon drum, both are mini 7 spline . The 0000 642 1240 Picco rim is 7 pin [tooth] with a mini 7 spline bore.
Its not recommended to run 3/8 standard rim sprockets because they don't mesh with the Picco to spec. The problem is the mismatch with the Picco undersized side link bottoms. A 7 pin 3/8 Picco rim is slightly larger in diameter then a standard 3/8 7 pin rim to make up for the difference in the side links.
A.404 rim actually works better meshing with the Picco chain surprisingly . But there is no such thing as a mini 7 spline bored .404 rim.
SawTroll
Quote from: HolmenTree on October 18, 2014, 09:56:54 AM
Surely, but my question was about the size (number of teeth in nose sprocket).
HolmenTree
Quote from: SawTroll on October 19, 2014, 01:14:24 PM
Quote from: HolmenTree on October 18, 2014, 03:29:02 PM
SawTroll
Thanks - it looked that way.  :)
I assume they are relatively light then, with the slim profile - but there are of course disadvantages with small bar noses.
HolmenTree
Quote from: SawTroll on October 20, 2014, 08:24:29 AM
The forestry company I worked for back in the day when we were logging with chainsaws had a safety policy, that only small radius bar noses were to be used.
Kickback injuries were non existent with our high powered saws with short bars.  Bore cutting with this b/c setup is very smooth and agile, anyone who differs in opinion doesn't know what they're talking about or just never have tried them.
Only drawback with small radius noses is durability and chain derailing when using standard 3/8 chain.
That's why we used the lower profile  Oregon 76/77LG and Stihl 33TS chain to curb the problem.
CR888
In Stihl's Australian 2015 catalogue they have a performance kit for the ms261 which is an 8tooth picco rim (silly micro spline size), 18" rollermatic e picco bar and a loop of PS3(full chisel picco). I think they claim it gives a twenty percent increase in cutting speed. Unless cutting clean green wood with top handles ect our wood down under gives picco chain a hard time.
HolmenTree
Quote from: CR888 on October 25, 2014, 06:56:54 AM
Here in Canada the MS241CM is available with that kit too but in 7tooth Picco rim though. Great setup for harvesting conifer pulpwood.
I have a 8Tooth Picco rim [part#0000 642 1241] and it's a good 1/16" in diameter larger then a standard 3/8 rim.
Part # for the 7Tooth rim is 0000 642 1240.
Rex Renolds
What size (tooth) Picco rim would you recommend using with the 9 tooth nose sprocket of the Cannon Super Mini bar mounted on a MS261 C-M?   are there different size noses sprockets available for the super mini in the picco pitch and if so what would be the ideal rim and nose sprocket to run on my saw with the picco setup?
         -Rex
SawTroll
In my book there are two flaws with that kit;
1) The 8-pin rim should have been a 7-pin
2) Putting "green" chain in a "performance" kit is an insult.
HolmenTree
Quote from: Rex Renolds on October 10, 2016, 09:18:07 AM
         -Rex
The Cannon Super Mini bar is a rebadged Windsor Mini Pro design.
I replaced the nose on my 18" Cannon Super Mini bar with a Windsor Mini Pro tip.
The Cannon bar is definitely better quality then the Windsor bars but the Chinese made tips on the Cannons are crap.
Windsor Mini Pro bars came in 1/4", .325, 3/8 , 3/8 LoPro  (Picco). I got all those tips and a small inventory of new Mini Pro bars.
8 tooth Picco rims are too large for the 261 size saws, run the 7 tooth.
SawTroll
Quote from: HolmenTree on October 10, 2016, 09:08:36 PM
Are the dl counts that Cannon currently is listing for those 18" bars (75dl in .325 and 66dl in 3/8") correct in your experience?
It is a pity with the Chinese noses of course, and it is hard to understand why they do it on otherwise excellent bars?
HolmenTree
DL count depends on make like Stihl versus Husky.
On my 562 XP with 18" Super Mini .325 I'm running a 74DL 23RS chain. Fits perfectly as the Windsor Mini Pro tip is shorter then the tip Cannon originally supplied.
Shorter nose profile design offers a stronger bar-nose joint connection . Something Windsor figured out years ago.
SawTroll
Quote from: HolmenTree on October 11, 2016, 10:32:07 AM
I figured it might vary slightly with saw brand, but it doesn't according to Cannon?
As 74 is with the shorter Windsor tip (the way I read it), 75 may be accurate with the original tip, or maybe even 76, on the Husky?
I assume you are using a .325x7, as that's what you recommend?
HolmenTree
Quote from: SawTroll on October 12, 2016, 12:22:47 PM
I figured it might vary slightly with saw brand, but it goesn't according to Cannon?
Here's a few pics Niko.
Yep running 7 Tooth. 325 rim. Cannon is probably specing for a 8T.
As you can see lots of slot adjustment  for the bar with the 74 DL chain.
Yes Windsor tip is shorter.
Cannon tip is shoddy, raised rivet heads and weak sprocket bearing.
SawTroll
How much difference do the Windsor tip vs. the Cannon one make? As it looks to me in the pictures, it should be at least one dl?
SawTroll
Quote from: SawTroll on October 13, 2016, 04:40:09 PM
Thanks for the pictures!  :)
Have you measuredHow much difference do the Windsor tip vs. the Cannon one make? As it looks to me in the pictures, it should be at least one dl?
HolmenTree
My pleasure to post pics Niko :)
Not sure about DL it's been a while since I changed the tip. It just so happened Stihl's 74DL loops works out fine.
I'll have to go back to the old Oregon loops hanging on the wall to see what I was running for DL
SawTroll
Anyway, 74dl is a more "likeable" dl count than 75 - but 76 is even more "likeable" as it makes a "perfect loop" (all sequences are complete). This hardly matters in practical use though... :) :D
I have a slightly uneasy feeling about Cannon dl counts though, as they aren't always "logic", and have been changed too often (in their listings). When you aren't cutting and spinning your own loops, this is an uncertainty that you (or I in this case) don't need.
Also, Cannon may be destroying their own reputation with those Chinese bar tips, and I don't understand why they do it.
HolmenTree
Quote from: SawTroll on October 14, 2016, 06:44:03 AM
I have had Cannon make me special order guide bars for over 30 years.
They specialize in making a high quality bar but they are not in the business making sprocket nose tips.
Seeing Windsor/Sandvik have been out of business manufacturing Mini Pro bars there is no longer a supply of those sprocket tips
So a Chinese copy cat supply can be bought.
I did get not bad service out of the Chinese tip but luckily I have a supply of OEM Windsor tips and I'm good to go.
I think Chinese product can be good quality under the right quality control. Stihl and Husqvarna have plants in China.
Remember back in the 1960s when a Japan made product was called "copy cat cheap"?
Well those Japanese Honda motorcycles that were copies of the British Nortons, BSA motorcycle turned out to be a better product then what the British could build.
Honda today owns the biggest share of Harley Davidson.
Can the Chinese do the same?
Here's a 1979 ad of the newly introduced Windsor Mini Pro bar.
Next pic compares the Windsor OEM tip to the aftermarket tip.
SawTroll
Well, the Windsor tip obviously is much shorter, and tapers much more abruptly as well. Is that nose a nine-pin in .325, vs, the "normal" ten-pin?
As it looks, it will "steal" effective bar length, in addition to what difference the length makes, as it tapers off too abruptly for any part of the tip to be considered for actual (effective) cutting length. As it looks to me, the Windsor "mini-pro" tips really is a very bad design, as they make you need a longer bar than other tips do (it is the same with the Oregon "double guard" tips - wasted bar length.
HolmenTree
Quote from: SawTroll on October 14, 2016, 08:52:40 PM
Actually Niko that Windsor tip has a 12 tooth 1/4" sprocket.
But my .325 noses are a "normal" 10 Tooth.
What's with the "pin" terminology? We're not talking about Danzco pin sprockets here :D
The Windsor Mini Pro tip is only 7/16" (10mm) shorter then the Cannon Chinese tip. Hardly noticeable in my opinion.
Take another look at the Cannon tip, notice how ugly high the rivets are and how they would snag and pinch in the wood kerf.
The shorter design of the Windsor is far more superior for durability, less flex with less chance of breakage at the bar joint.
Plus less chance of the sprocket and bearings getting pinched and burning out.
Notice how the Chinese tip needed 3 extra rivets.
The shorter tip also offers less chance of chain derailing.
Now to the Oregon PowerMatch tips , the small radius 9 Tooth 3/8" Double Guard PowerMatch tip is longer then the standard 11 tooth tip, so a longer bar is not needed.
I love those Double Guard PowerMatch bars, super smooth in limbing and bore cutting and near zero  kickback energy. ;D
Awesome last pic of a low top Husqvarna 576XP AutoTune with a 20" Double Guard bar 8)
SawTroll
I follow you in most of what you wrote there, particularly the comments on the Chinese bar noses (tips) - but I just can't agree that "pointed" bar noses are an asset.
Of course a short bar nose will be stronger at the joint, as you say - but it also means that more of the "slap wear" from the chain ends up on the bar body itself, instead of on the replaceable nose. At least Oregon used to say that, related to their own relatively long replaceable bar noses, and I'm fairly sure that their point is valid.
This isn't something that will keep me away from this or that - just something to be aware of.
One thing is for sure though, after seeing your pictures of the Cannon noses, I am not going to buy any Cannon bars until they come up with something better - they look horrible!
10mm difference should normally mean one dl (actually slightly more, but far from two) - meaning that 75 dl likely is correct with the original nose - at least with a 7-pin drive rim.
HolmenTree
Quote from: SawTroll on October 15, 2016, 11:12:21 AM
Well small radius bar noses are a great asset when they are proven to reduce kickback energy significantly preventing countless potential injuries.
Let the pro grade safety bar nose do the safety work rather then using a poor cutting yellow chain.
One method to prevent that.....proper chain tension.
The middle Windsor Mini Pro bar in the pic has alot of hours on it and no evidence of damage to the bar rails from "chain slap".
HolmenTree
Here's a closeup of the high hour Windsor Mini Pro bar.
You can notice a bit of indentation wear from the chain coming over the bar nose. But no where near the bar rails.
Proves the Oregon theory is a bit full of wind.
The chain wear from rotation only follows the diameter radius of the sprocket nose.
But I have seen wear and chipping of the bar rails near the joint, but that was from limbing spruce in freezing temps. Loose chain tension was the major cause.
SawTroll
HolmenTree
SawTroll
Well, I still believe that most people will have most of the wear further back, caused looser chain.
