In need of help with woodmizer gremlins ( she's all fixed up)
Started by forester2009, October 13, 2014, 06:03:16 PM
forester2009
 To keep a long story short.   I was in the process of cleaning up my mill, wich I haven't run in a long time.  I have a lt70 with the cat diesel and the starter doesn't seem to be getting any power.   I have power to the controls but when I turn the key I get nothing.  Not even a click.  Any suggestion on where to start.  Also my hydraulics wont respond either.  I can hear clicking though coming from the hydraulic box.  I look forward to your responses.
2006 WoodMizer lt70 Cat diesel Command Control,  Corley Two Blade edger, Case W7 wheelloader,  Old Hmc Debarker,  Cat Genset
47sawdust
My Kubota wouldn't start a couple weeks ago.The lights worked,had 12.6 volts in the battery and at the starter.It turned out the battery had an internal short.We put jumper cables on it and it fired right up.I'm grateful for a savy mechanic.Might not cure your problem,but someone will be along with a solution.
Mick
DR_Buck
Check the battery voltage.  It may be dropping down under load.   Hydraulic pump and starter draw lots of current.
highleadtimber16
A test light is a good friend in these situations.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
scully
I would check fuses , grounds , battery , has the mill gotten wet ? any corrosion on contacts ? A low battery can cause all kinds of issues . I hope this helps . As a side note do not attempt to use hydraulics with low battery trust me it aint good ......
I bleed orange  .
forester2009
Battery is reading 12+ volts even had a battery charger on it.  I also tried another battery.
drobertson
I hate to say it,, but unless you like chasing your tail,, give wmz a call, it would cut down on a few circles.
LeeB
Follow the power source. Sounds like a bad connection somewhere. Sounds like a bad ground to me.
forester2009
Drobertson
That would be the least amount of headaches.  I've chased my tail enough In life
forester2009
If you had to guess which ground conection would you start with
backwoods sawyer
The one on the bottom rail.
Gunk gets in there not allowing it to make a ground.
If that don't solve it get out a volt meter and start at the battery and work your way thru the starting system.
Backwoods Custom Milling Inc.
MartyParsons
    Hello,
    Sounds like everyone has you going in the right direction. Here are a few things to think about.
    I would start here first.
    Facing the radiator on the right side of the Cat engine remove the black cover that has the glow plug relay and some other electrical connections. There is a manual reset circuit breaker that may trip. It will cause a no crank issue. It is a small tin box with red wires attached. There is a black button on the side of it. You should be able to push the button if it tripped.  You should hear a click.
       It takes at least 9 volts to excite the starter solenoid.  Check voltage at the blue wire on the starter. Turn key to 3 no voltage then go back to the circuit breaker. There is also a breaker in the control box under the key switch.
         Ground for the mill and the hydraulic pumps are through the bottom rail. The engine grounds run through the mill from the battery ground post to the engine and more.
        If the bottom rail has rust on it remove rust with wire brush on a drill. I use a 4" grinder with a stiff brush attached to the arbor.
        I would not start here but something to think about.
    I assume this is a early LT70 there were some wiring issues in the control box under the water bottle. The connector would saw through the wires.  :o
        There has also been some upgrades to the fuse block. There are two Red wires on the top left post, Are they loose? The fuse should be on first then the wire terminal then a lock nut. The nylock nuts usually melt and the nuts come loose. I toss them and add two nuts or a swedge lock style nut.
    If the fuse stud is loose or the block is burnt replace it.
         If the fuse has black in the center then you have the new design fuse block. No worries if you have this.
         A 12 volt test light and a volt meter works well if you call WM and they ask you to do some tests.
         I always start at the battery, check voltage if it is 12v and then you put a load on it. ( Engage the starter or the hydraulic pumps) It should drop but not more than 3 or 4 volts. Then move the the fuse block. Old style fuse the top fuse is the control box and the bottom one is the hydraulic pumps fuse. Do the same voltage check here.
    The hydraulic pump may be related to the engine no start or be something else. These systems are separate after the fuse block.
       If everything checks out. Then call us. I could keep going but that will get you started.
    Hope this helps.
    Marty
Good to know,  and Marty is with WM   :)
mikeb1079
the willingness to help from people like marty is one of the reasons i bought a wm.   8)
homebuilt 16hp mill
terrifictimbersllc
How do you know your battery is in good shape?  Hydraulics that only click, wouldn't be that crazy for the starter not to do anything.   I'd take a jumper and test the spark from the red power wire on the starter to the frame.  Or better put a meter on it there.
highleadtimber16
I agree with Marty on that little button inside the black box. I had a low battery on the mill, went to start it and didn't have enough juice so it blew the breaker.
EG 200 Wood-Mizer
giant splinter
Any little critters take up residence in there during your absence? this should show up during your testing process, but its always good to have a look at all the wiring that is exposed and in places where rodents can hide.
roll with it
drobertson
bad or low battery, and or solenoid(s)
woodmills1
Again I will say this thread shows just how much/ how far the good guys at WM go to help the users get the machines to do what they are supposed  to.  As a 70 owner I know that sitting idle is a bad bad thing.
barbender
When my 40 sits idle mice try to take over :( And rust, and a few other ills. Letting your mill sit is almost as bad as borrowing it to your brother in law :) (mine sits a lot).
dgdrls
Quote from: barbender on October 14, 2014, 08:48:12 PM
Put some drier sheets in the air-cleaner and some near your
engines covers and control boxes.  Keeps the rascals out.
DGDrls
POSTON WIDEHEAD
Quote from: dgdrls on October 14, 2014, 09:15:06 PM
DGDrls
So you're saying....if I have a hole in my laundry room where mice have been creeping in, I can stuff that hole with drier sheets and that will keep them out? This is a problem my wife has and she doesn't know what to do.
barbender
I just picked up some more moth balls. That keeps them out of the control box.
Quote from: POSTONLT40HD on October 14, 2014, 09:30:56 PM
DGDrls
No, we are saying stop chewing holes in your walls, you old goat ;D
Stuff the holes with steel wool.  Goats don't like to chew on it.
forester2009
Up date
The breaker on the side of the motor was the issue with it not starting.
The solenoid  that powers the hydraulics was bad.  New one on order.
Thank you all for all your suggestions and helpfulness.
