Nice change from blowdown salvage
Started by Ken, October 03, 2014, 08:09:46 PM
Ken
We've been chasing blowdown since July 4th.  The 70 acre block we are on is also about 40% blowdown.  We were however in a nice standing patch of predominately spruce over the last couple of days.  Biggest production days I've ever had.
Jamie_C
If much of the stand looks like that it would be a dream to harvest.
1270d
The new machine showing any glitches or all smooth sailing?
SliverPicker
I've been in blown down garbage since July.  I can't wait to find something else.  Congratulations of getting in to a good patch of trees.
Yooper by trade.
barbender
What kind of production numbers are you seeing, Ken?
1270d
Ken do you multistem quite a bit?  It looks like you have the extra clamp on top of the wishbone.  How does it measure?   I have never quite figured out how to get consistent length measurements with two or three stems.  Seems one will always stick a little bit and end up behind the others, or one will drop out of the wheels.
Ken
Quote from: 1270d on October 05, 2014, 08:09:43 AM
I've used the multistem arms quite regular when cutting small diameter random length pulpwood.  Sometimes if you get two or three small trees positioned right you can do 8' reasonably well.  I think the key is to get the first one directly in the middle of the grab arms and top knife.  I also like the extra arms for plucking unmerchantables out of the way.  The machine has been relatively trouble free to date but only a little better than 500hrs clocked so far.
Quote from: barbender on October 04, 2014, 10:12:34 PM
This block has been averaging 12 - 20 m3/hr with an average piece size of 0.35 m3.   The best area did not last long and I was back into blowdown yesterday.
barbender
When I follow processors that multi-stem, I have to pick a lot of out of spec wood out of the piles. That could be due to the operators as much as the process. Ken, that would be around 4 to 8 cords an hour, right? I think we use a conversion factor of 2.4 m3 per cord.
