hour meter on 548E
Started by Nemologger, October 01, 2014, 04:40:04 PM
Nemologger
my hour meter stopped working on my 548E skidder... How can I check it to see it its the meter or the wire?
Clean and Sober
BargeMonkey
 Do you have a test light ? Multi meter ? Check the fuse panel before you go thru alot of trouble, sometimes hour meters and dash lights arue on one circuit. If you get it out and cant tell, 2 pieces of wire with alligator clips hooked to something of the appropriate voltage should tell you.
Nemologger
Thanks for your reply BargeMonkey, I found the problem....bad connection
Clean and Sober
BargeMonkey
 The woods gremlins    :D
Just make sure that stuff is taped, wire nut-ted or connected properly, a faulty ground, short or electrical problem can turn bad quickly. I had a loose wire in my dash panel on the landing loader last week and watched the smoke start to pour out, which leads to bad things.
