How to encourage blue stain in pine.
Started by Joe Hillmann, September 26, 2014, 11:50:57 AM
Joe Hillmann
I have a bit of an unusual problem.  I make rustic crates with the lumber I cut on my mill.  By rustic I mean the rougher and worse looking the lumber the better.  The pine that I cut in the summer naturally started growing blue stain.  Now that the weather is cooling it isn't growing anymore and some of my repeat customers are complaining that the crates I am sending them are not rustic enough.  So is there any way to get blue stain to grow in the fall and winter?
I have thought of soaking the piles with water than completely covering them with black plastic to trap the moisture and collect the heat from the sun. Any other suggestions?
mmartone
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
red oaks lumber
wet each layer and dead stack it, that will work until the logs are frozen.
LaneC
You may also try going to the "wood processing and drying" part of the forum and ask "Genewergart  wood doc" He is very knowledgeable in the stained, mold and fungus fields.
Man makes plans and God smiles
Joe Hillmann
BradMarks
This is interesting. Blue stain occurs naturally in Pines out here that have been standing dead for awhile - such as after a fire. Except for custom work, it is generally undesirable, and therefore there is a huge push to get the dead/dying out of the woods after the fires. I didn't know you could "encourage" it after cutting live wood.
Joe Hillmann
Quote from: BradMarks on September 26, 2014, 02:19:09 PM
I just looked it up.  It appears as if blue stain has different meanings.  In the Rockies and west it is a fungus that is spread by beatles that prevents the tree from defending itself from the beatles and eventually kills the tree, it ends up with the sapwood turning blue.
Blue stain can also be any type of fungus that grows in the wood after the tree is cut and before the lumber is dry,  it isn't the same as mold or mildew.  Mold or mildew grows on the outside of the lumber, the stain grows inside of it.  It can be caused by many different types of fungus.
The second one is the one I am trying to grow.
Dave Shepard
You are only going to have blue stain in the sap wood. Do you have a warm garage where you could dead stack your outer boards and keep them moist? Right after the blue stain comes the white mold. That's one step too far. :D
backwoods sawyer
Then comes those little grubby things that like to decorate your wood as they feed.
Still rustic ;D
Backwoods Custom Milling Inc.
Nomad
     If you lived down here, figuring out how to get pine to blue stain would be the least of your problems. :D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
customsawyer
This is like asking how to herd cats. :D No one has ever done this before but we are all ears on what you learn.
www.thecustomsawyer.com
You need heat and humidity for blue stain. The surest way is to cut as much pine as you think you will sell in the hot humid summer months. Before really cold weather you could try dead stacking and cover with black plastic. Frank C.
Bandmill Bandit
Without Pine Beatle Pee you are wasting your time.
I have been told by a provincial government foresty guy that there really is no other way to get it. It contains a bacteria/fungus that when exposed to air and moister and warmth it will start to grow.
I would NOT however Recommend growing Pine Beatles.
The black plastic should work.  There is moisture in the wood and the black plastic will trap the heat that you need.  Not sure if it will work after freezing weather, though, as the fungus that causes the stain may not be active.
WoodenHead
I still have about 20,000 bdft of pine to cut.  Since it has been sitting around through the summer, I'll be seeing lots of blue stain (caused by heat and humidity around here).  I'd be happy to send you some.   ;D
justallan1
How about contacting other local sawyers and either working a trade for you "undesirable" perfectly good wood or possibly just buy their logs with blue stain.
I've known guys that did the rustic look on things for people and understand what they are wanting. Another great trick they used was taking a chain with a bunch of bolts run through it and beating the heck out of the boards before building or burning them a bit then cleaning it up halfway and building.
Allan
Peter Drouin
Quote from: WoodenHead on September 26, 2014, 08:42:50 PM
Why would you have all that Pine lay all summer? Did buy it or just cut it off your land?
A&P saw Mill LLC.
WoodenHead
Quote from: Peter Drouin on September 26, 2014, 10:28:10 PM
I buy pine from loggers who only supply it during the months between November and February.  Since I sell lumber I have to guess how much I might need.  At the time it looked like milling was going to be my primary source of income, so I bought a good bunch of it.  Then I got busy doing other things.  So, I wasn't able to saw as much as I had hoped before blue stain set in.   :-\
slider
Jo I'm thinking a woman I know stained some pine by using vinegar and steel wool.It gave it a rustic look.
al glenn
drobertson
Leave the bark on the logs, and let them sit for a spell.
ellmoe
  Come to Florida. Cut down a pine tree. Turn around twice. Presto! Blue Pine!
POSTON WIDEHEAD
IMO...Blue stain only occurs in Pine when it is in log form. After you saw a log into lumber and there is no
Blue Stain showing......it is impossible to produce Blue Stain. You can easily produce Mold....but not Blue Stain.
Mold and Blue Stain may in fact be from fungus.....but the Blue Stain that some of us look for MUST occur by natural process and CAN NOT be made to happen.
Bandmill Bandit
Seriously guys I have cut lot of pine. I have never seen the blue stain in any logs that did not have evidence of Pine Beetle  infestation.
Nor have I sawn a log with evidence of the Pine Beetle that did not have at least a hint of it.
More than a few people refer to it as denim pine and it commands a premium dollar.
Bandit,
In the deep South, the blue stain fungus that we are speaking of has wind borne spores.  The fungus will grow in freshly cut logs if it is hot and humid, and the fungus does not require the beetle as a vector.  However, if the beetles do attack, the fungus comes in with them, too.
