cutting cookies this month
Started by tule peak timber, September 22, 2014, 06:53:58 PM
tule peak timber
Seems like things run in streaks, and this month it's cookies. A few pics from around the mills today Rob.
Joe Hillmann
What is the plan for the big ones?  They look very unstable.
tule peak timber
Joe ,they will be finished out as counter tops for a customer.
Seaman
Rob, those are big ! Sometimes when I cut cookies the bar climbs a little, with the same chain that rips straight. Ever have that happen?
Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
tule peak timber
Climbing is a sign something is wrong with your tooth geometry. I'll check tomorrow but I think the grind we are using is actually a little off spec but rips AND cross cuts spectacularly .Have we had trouble in the past with geometry- you betcha ya ! Learning from mistakes is how we operate around here LOL.......
Delawhere Jack
The surgeon general recommends that you consume no more than 1 mega cookie per week, due to calorie content.  :D
kelLOGg
I ask this question every chance I get. How do you keep them from splitting? You have pallet full of oreos and the climate looks very dry which would accelerate drying (cracking) on every one if I cut them. What's your secret?
Bob
tule peak timber
KelLog, Epoxy, how you use it , and when . Not to be cryptic, but these larger rounds will go to the kiln this week , then to a multi week process with different epoxies , fillers , then shot with conversion varnish and rubbed out to a low sheen. Will they split , yes , then I deal with it .... Rob
drobertson
the secret is out!  super glue, believe it or not!  nice cookies rob!
YellowHammer
I use this visual aid to explain to customers why the cookies I saw for them will try to split due to drying stresses.
Here is a poplar cookie, cut perpendicular to the log, one inch thick, and as soon as I milled it I took a circular saw an made a single cut from the edge to the center.  As the cookie dried, the saw kerf widened up and now looks like a pie wedge is missing.
Yh
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
mikeb1079
Quotethe saw kerf widened up and now looks like a pie wedge is missing.
maybe pac man ate a piece.   :)
homebuilt 16hp mill
That "pie with a piece missing" also gives a clue as to how to make a cookie table.
Cut 2 (or 3) cookies, and make a saw cut like YH has in each one, and put them up to dry. They will certainly shrink in the way shown, but because there is a straight cut, that opens up, with a fairly straight edge, and the rest of the wood shouldn't split apart.  Once dry you take your middle piece and cut out a couple of wedges to glue in the gap. The grain will match up pretty close because the pieces came from consecutive slices, and because the wood is now dry, future movement will only be small.  Glue it all up with epoxy and carry on.
tule peak timber,you have got some cookies there!!  And than some.
scsmith42
Quote from: Ianab on September 23, 2014, 12:42:43 AM
Great info - thanks Ian!
YH - good visual - thx!
Rob, I always love your posts!  After seeing that photo, I think that I'll start referring to you as the "cookie monster"!  :D
Tom's 3638D Baker band mill
21incher
Nice stack of cookies, and I thought everything was bigger in Texas :)!
tule peak timber
Madrone flavored cookies today. Rob
hackberry jake
It looks like that came from an OLD log.  smiley_old_guy
tule peak timber
This log has been in my log deck about 8-9 months.....
backwoods sawyer
Backwoods Custom Milling Inc.
tule peak timber
No very little....Grows up north and at 5$ per mile to get it here most  ends up not coming. I can get plenty ,,,,,just a matter of $$$$$$$. This was just one of two logs I bought from a freeway by-pass project consisting of mostly Valley Oaks, Quercus Lobata.
js2743
Looks like you found a clock in the big one.
golddredger
I scored some madrone last summer. Brought it home in 8ft logs 36" dia. Coated the ends very well and put it in the shade along with my oaks. Came back to grab an oak one month later and the madrone looked like a bomb went off inside of them. Full checks all the way through the logs big splits all the way around. Junk as far as I was concerned. I cut it into fire wood. What's the trick? I see your slice has the small outside checks all the way around. Within a few days those would be clear to the center for me even coating and keeping in a cool spot. Any tips. The wood when fresh cut is awesome. I was going to make some tables with it. Hope to try again. I can get all the madrone I want but have not after that first go around.
Home built bandsaw mill and trailer for a mini logging operation. Lots of chainsaws and love the woods.
tule peak timber
Golddregger, You have weather conditions similar to my location... You must run a rain-bird on your log deck , every day. Madrone is problematic , right from the start so I only cut and sell 4/4 as I have good luck with it. Thicker tends to warp badly, sticker stain, and is a real insect magnate. Thicker boards need to be slaked a second time before going into my secondary shop. It is a twisty tree that grows on mountainsides after all. Modest drying rates.... Attached pics are of a table I recently built for a certain TV guy. Cheers  Rob
hackberry jake
Certain TV guy... now you're just teasing us.
tule peak timber
More Madrone today. This piece is 34 inches at the narrowest spot. Pretty stuff.. Rob
