The hidden enemy of Bandsaw Blades
Started by prittgers, September 14, 2014, 10:48:50 PM
prittgers
It's easy to blame the dirt and grit in the log for the seemingly short life of our expensive bandsaw blades.  There is a hidden destructive force, though, that makes razor sharp blades break with a frightening bang.  The terrorist is actually the stress of the blade flexing and straightening as it moves round and round the wheels.
As one who sharpens a lot of blades for both pro and hobby sawyers, I have come to understand that a good operator knows that about 2 hours on a mid-sized mill is all it takes to create these microscopic cracks.
After several hours the blade performance drops and the sawyer usually takes it to the shop.  But, even though the profile and razor sharp cutting face can easily be restored - the hidden damage is the stress crack.
Keeping your run time to about 2 hours and having the blade precision ground eliminates these cracks.  They are forced to start forming all over again - vs simply quickly propagating down through the gullet.
A good grind eliminates these life-robbing stress cracks!
Parker Rittgers
Professional Sawyer, Retired, well, not really !
WoodMizer Alaska | 907.360.2497 cell 336.5143 office BevelSider.com ? Everything BevelSider
907.336.5143
prittgers@aksamill.com
Chuck White
Good point!  smiley_thumbsup
I've found that to be quite accurate!
5quarter
Excellent photo of the trouble. notice the cracks are to the top side of the blade which is always under tension around the wheel, while the bottom is always under compression. Time in service though really depends on the composition of the steel, thickness of the band and the degree of radial curve. using a thinner blade body, a more malleable steel and larger bandwheel would likely extend the run time significantly.
Blue Harbor Refinishing
DMcCoy
Quote from: 5quarter on September 15, 2014, 01:31:44 AM
Also they are in the gullet where the blade is narrower and takes more of the bending.
This is a great topic, Thank you!
EZ
Looking at the deep of the cracks it looks like I need to sharpen my blades 4 or 5 times in order to get read of the cracks. Is this what you guys do. EZ
scsmith42
Tom's 3638D Baker band mill
Chuck White
I don't run my blades to the point where they're "really" dull, so I have been having pretty good luck just setting them and giving them a light grind!
drobertson
It should be mentioned that certain blades inherit this type of cracking much more than others.  Most are of the microscopic nature.  these look pretty far gone.   I run a simple face grind on the tooth, have for several years now,, only the occasional break, mainly due to a chunk of debris that creates too much stress.  I do suppose cracks present are there, but have never seen anything like these shown.  I will admit, I'm not a blade sharpening specialist,  just a simple tool maker that likes sawing wood, if I ever see a crack like this shown I would just trash it for sure.
EZ
I do also have real good luck with my blades. I try and get read1000 .bf out of one but most of the time when they get to dull it gets harder to push threw. That will be my next thing I do on the mill is put had drive on it. If I can ever figure it out. It's probably been a couple of yrs since I broke a blade. EZ
hackberry jake
I'm impressed with how smooth the grind is on that band. Usually at that magnification, you can see grinder marks. Also, smaller HP mills can run a band through more sharpenings because the gullets don't see as much stress.
Peter Drouin
Quote from: hackberry jake link=topic=77762.msg1180865#msg1180865 date=1410820083, smaller HP mills can run a band through more sharpenings because the gullets don't see as much stress.
/quote]
My cat eats them up, but It puts out a lot of wood too.
A&P saw Mill LLC.
License NH softwood grader.
hackberry jake
I would gladly trade out blade life for the performance of a big diesel. Bands are a pretty small cost in the big picture of things, and high hp mills get a lot more board feet cut before the band is too dull to keep going. They take a bigger bite
My mill = food1
Diesel mills = sketti_1
Peter Drouin
Quote from: hackberry jake on September 15, 2014, 10:13:10 PM
My mill = food1
:D :D
A&P saw Mill LLC.
shinnlinger
My Turner rolls around highway trailer tires.   That cushion of air absorbs the expansion and I have only broken one band (on a lag bolt) in the 7 years I have run it.
Why dont more mills don't run on tires?  I cut beams perfectly square.
Shinnlinger
hackberry jake
At what blade width do you toss your blades shinnlinger? I haven't broken many. Mine either have a devastating metal strike that messes up the set too much or it gets close to 1" and I'll toss them.
ely
i run a norwood, and with the 20 hp I know I load it up sometimes. being a manual mill I can feel when it gets dull so I change it. I run the catclaw sharpener and I usually only set the band about every third sharpen... I will get a band to break once in awhile, but it is most always on a band that has seen better days.
when the bands get too short that I cant grind the gullet on the catclaw they usually break the next time I use them... if I ever get one to last I will just face grind the teeth and saw a bit longer :D
I have noticed that after I use up almost 1/8" off the band that I do have to set more often, it seems the good steel that holds the edge gets ground off with use and the softer steel needs worked more often.
