Blade tension question
Started by Darrel, August 31, 2014, 01:46:48 PM
Darrel
My blade tension gauge on my LT40 is not the original. How many PSI do I need to achive the proper tension.
Darrel
1992 LT40HD
Delawhere Jack
I honestly can't remember. I go by the yellow and orange ranges on the gauge... :D
I think the lower range (yellow) starts at 2,300lb and the high end orange goes up to 2,600lbs. That would be for 1 1/4" bands.
Lately I've backed off on the tension some, I was starting to break more bands than I'd like. For general, not too big -- not too hard logs I'm running around 2,400 (low to mid yellow zone), and only cranking up the tension on difficult materials or if there are large knots.
CalebL
I tighten my blades as tight as I can get them. I max out my gauge.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
york
I crank mine up till my arms get tired....
Albert
POSTON WIDEHEAD
Darrel
Thanks, I was sure that I wasn't cranking it up enough, I was only running 1,800 and it was a bit wavy.
1992 LT40HD
Dave Shepard
Chuck White
My mill still has the original gauge, and I run on the line between the yellow and the orange!
I may be wrong, but I still think that running too much tension is hard on bearings and B-57 belts as well as blades!
Dave Shepard
I go by WM's recommendation. I was told that I should run that with all bands.
backwoods sawyer
Quote from: york on August 31, 2014, 03:22:37 PM
So I, little Jo takes the slack out of the saw so 24 1/2 turns puts me at 80 psi with the air bag system. WM had me up my tention from 60 to 80 and indicated some prefer 90 psi. I would much rather pull lumber all day then do four saw changes in a short time ;)
Backwoods Custom Milling Inc.
Darrel
So I upped the pressure to about 2500 and it cuts much straighter and smother.  :)
1992 LT40HD
DGK
2800 - 3000 psi. The more tension the better.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
terrifictimbersllc
My gauge got forced somehow so that the zero pressure position is now at 500 psi.    Is there any way to open it up and reset the pointer?
Yup, mine is at about 250, but it is a sealed unit with glycol used as an damper.  Maybe it could be unscrewed, but it would have to be removed first.  Bob, the WM traveling technician, said to just crank it that much further around.
gimpy
I just got back yesterday from a 600+ mile drive to have my used 2001 LT40 looked over and be trained by Woodmizer outside of Portland Oregon. My guy (James Guerard) told me to try to keep it at 2500#. By far, the second best money I've spent was (first the mill) getting trained at Woodmizer. We went over everything. He/we opened up everything and did everything that needed to be done and got all my questions answered. ordered some new standby parts and put on a new blade and got set up with resharp.
Haven't started making sawdust yet as I have to wait for a new fuel pump to arrive. But everything else is in working order, calibrated and lubricated.
Gimpy old man
Lucky to have a great wife
John Deere 210LE tractor w/Gannon Box
blade69001
  I only tighten down on the resaw when we are running oak and Hickory. It doesn't have a gauge but instead it has the bolt and pad like the  the LT 15.
  http://www.youtube.com/watch?v=9jL1MWANivQ
The rest of the time i have between 1/16th and an 1/8th of an inch of pad beyond the bolt head. It works great and I get between 1500 and 2000 bd ft of cutting between blade changes.
Sean P.
Ps I have no idea if this is the right way I just know it works for me so if someone knows a better way to get better results I would love to hear about it.
Just being me, But it is ok you do not have to like me.
backwoods sawyer
Hey Gimpy what part of south central are you located?
gimpy
Northern Chiloquin is where the farm is. However, we live mostly in K-falls at the moment. Selling the house and moving onto the farm to build our real log home and our future. Gotta get away from people. Smile
Gimpy old man
backwoods sawyer
I make the loop over thru there with the mill every so often.
Mill for a firewood processor south of Tulelake, and another over between Lakeview and Paisly.
The trip up north is worth  smiley_thumbsup smiley_thumbsup ;)
thechknhwk
Anyone ever crank the blade tension up over spec on the 35,28 or 15?  If so what were the results?
gimpy
Next time you come this way, PM me and I'll buy you coffee or lunch. Whatever you have time for. It'll only cost you a little picking of your brain. Experience is always welcome.
Gimpy old man
highleadtimber16
Wood-Mizer told me that running your blade on a higher tension vs low tension actually reduces the chances of it breaking/cracking. Exact opposite of what I and most people think. Ever since they told me that, my number of broken bands has gone way down. I usually run it around 2800-3000
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
Chuck White
Quote from: highleadtimber16 on October 02, 2014, 11:12:05 PM
Just doesn't make sense to me.
Rachiano
I run al lt70 with the airbag tensioner....recommended by wm is 80psi tension on 1.5 inch bands. I run the .045x1.5inch bands. Pumped my airbag to 120psi and tension blades to 130psi on the gauge. Had a wm rep here and he had a gauge which is fastened on the blade to check the actual tension....the measurement was 35000 pounds....which is very low to the 250000 pounds the blade can handle before it breaks....so i say tension as much you can...works great for me sawing all those tropical hardwoods.
Rachiano
WM LT70
WM EG50
Werklust WG25 Wheel loader
DAF 2100 HIAB truck
