Woodmizer lt35 hd log loading cheat with a logrite
Started by mrector, August 19, 2014, 03:20:46 PM
mrector
This past weekend I milled up a couple nice walnut logs and the big one was way to heavy to get on to loading arms with just the logrite. So I used one of magicmans tricks and used the hydraulic clamp to pull it that last lil bit onto the loading arms.
I shot a quik video.
Woodmizer lt35 log loading cheat logrite: http://youtu.be/kx3aUqKrSHs
Thanks Mikey
Woodmizer LT35HD25 brand new!
Stihl 044 and my favorite: ms260 pro
Homemade logging arch
Homemade hitch log picker-upper
DanG Deadheader log loading trailer.
mrector
New Brunswick
POSTON WIDEHEAD
If you have a sawmill....and you have a log.....you will some how figure out how to make boards even if ya tear the DanG thing up.  :D :D :D
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
It works well doesn't it?   ???
I keep my engine running when the hydraulics are being used.   :)
POSTON WIDEHEAD
Quote from: Magicman on August 19, 2014, 09:41:34 PM
While we're bragging......so do I.  :)
POSTON WIDEHEAD
Ga Mtn Man
I discovered that if you hook a cable to the debarker blade and run the cable through a snatch block it makes a dandy winch for loading logs.  I'm sure I've got a video of that around here somewhere.  Really. ;D
Do not do this.  I have never actually tried it and it probably wouldn't work anyway (and may possible be slightly dangerous to you and your mill).
Nomad
     Mrector, I've done the same thing several times.  But I think it'd be a lot safer to order a hook from LogRite and do away with the peavey.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Jemclimber
Nomad,  could you elaborate on your safety concerns?  Do you think the cant hook shaft will bend?
lt15
I use hooks.  (End tongs)
For turning.
And rolling.
And moving.
And loading.
Built from broken/discarded logging tongs.   :)
Nomad
Quote from: Jemclimber on August 20, 2014, 06:51:15 AM
     No, but it's difficult to keep the peavey vertical without someone standing there to hold it.  If it flops to one side it'll come out; the log may reverse course and the peavey can get airborne.  (It did it to me.)
Lucas DSM23-19
