wm blade leaving undesireable surface
Started by yukon cornelius, August 11, 2014, 10:47:49 PM
yukon cornelius
i have only ran timberwolf blades so far but I got 3 wm blades and put the first one on for a try. it cuts fine but is leaves rougher mill marks every couple inches on the board face. im sure its just a tooth or couple teeth with different set on them. I haven't contacted them nor have I tried the other 2 blades. any suggestions?
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Delawhere Jack
There's a tooth or a couple teeth knocked out a bit. Usually happens in shipping. It was more of a problem when they shipped them coiled. Now with the flat pack blade boxes it's pretty uncommon. If it's really off, you may be able to find the tooth by feel while slowly rotating the band by hand and bend it back with pliers.
LeeB
You could put your eye on the blade and see if you can find the guilty tooth and gently reset it with a cresent wrench or you can use the blade to cut boards you won't be so critical about. Hopefully the tooth will get reset correctly on the next sharpening.
POSTON WIDEHEAD
yukon cornelius
no debarker but these are erc logs that the bark his easily hand peeling prior to milling.
Brucer
It's probably more than one tooth that's off a bit. I found that when a blade marks the boards, it's usually 5 or 10 consecutive teeth that are overset (or underset).
This happens from time to time but it isn't often that you'll find a WM blade marking wood straight out of the box.
I'd try another blade. If that one also marks the wood, check the serial numbers on the blades to see if they're close. If they are, there may have been a problem with that run of blades. I'd complain to WM if it happens with more than one blade: they'll probably replace them, or resharpen them; and it will help them with their quality control.
Bruce    LT40HDG28 bandsaw
just_sawing
I sharpen blades for people and this happened with a new customer who refused to pay me for sharpening. I finally pen it down to the employee in the shop throwing blades on to a hard surface to uncoil them. Could not understand why their blades had a mis set.
I have ran WM blades for twenty years and never had that problem. It was either shipping or sorry to say handling at your place.
You can follow me at
www.http://haneyfamilysawmill.com
I've had Tmberwolfs do that. But that was a blade that I had for a while. I did find the teeth that was doing it. I made it better,but still could see where it was not quite right.
Peter Drouin
When I have a blade that's not right. I give it a set and sharpen and if it doesn't come out of it, I throw it out and grab another one. Blades are short money. Blades are the heart of the mill, Don't cut with a bad heart. :D
A&P saw Mill LLC.
License NH softwood grader.
drobertson
Yes, I too have seen this from many different makes and shapes. It is rare, but happens, try another one and save that one back if it saws unsatisfactory for this job.
ladylake
How bad is the surface, keep in mind this is rough cut lumber and it will be planed or if used for trailer decking or fence boards a little rough is fine.  Quite a few people like too buy circle saw lumber just for the saw marks.   Steve
yukon cornelius
the surface isn't so bad as I cant use the lumber. I use my rough cut lumber to make rustic furniture. I like the rough cut lumber look but I like it to be consistently rough. I will see if I can find the problem tooth/teeth and correct them. thanks for your help!
Leaving random irregular patterns could be something as simple as feed rate, blade tension, drive belt tension, or even the log itself.  Of course, irregular tooth setting could be the culprit.  Whatever the cause, apparently the blade teeth are catching and slowing the blade speed rate down.  An oscillating blade will leave patterns.
yukon cornelius
mm the pattern is pretty uniform leading me to the tooth set hypothesis. flat about 6-8 inches then about 1-2 inches of the stipes , teeth marks, then back to normal.  it continues through the whole cut. I forgot to look to see if it list the top or bottom of the cut. its not both sides for sure. today I will run another through today and see if I can pinpoint it and fix it. can I lay it on a flat surface and look for the high or low teeth? I would say they are low since it leaves a ridge or raised area.
Dave Shepard
If you are going 6" to 8" between marks, you must be feeding about 200 feet a minute. :D When I have a blade making marks, it's usually about 1", at most 2" apart, and that is with a high feed rate. Are these marks like washbaords? That would be a feed rate problem, not a band set problem.
ladylake
Dave's right 6 to 8" would be a really high feed rate.  I don't know what kind of mill you have but maybe check the track rollers for bad bearings or a buildup on them which could cause the head to go up and down a little, that 6 to 8" would be one revolution of a wheel somewhere just over 2"  .  Steve
yukon cornelius
that's a great point! I feed slow! I aim for a very uniform sawmarks. manual ez boardwalk mill. I will check the rollers. that is a highy likely cause I never considered. thanks
You are back to blade oscillation.  Too slow feed rate not applying enough pressure against the blade can allow oscillation.
yukon cornelius
maby I do need to feed through faster. I didn't end up milling anything or checking the rollers today. I am going to check them on the way to the house for dinner. mill is between house and shop. I try to feed slow since im normally milling really knot infested red cedar. I thought it would give a straighter cut. it never did it before on the 11 timber wolf blades I had before so I thought it might just be the wm blades
Cedarman
Do the marks look like close together ripples that run about 20 to 30 degree angle across board?  Or are they ripple looking but run perfectly crossways to the board?  If you have a junk cedar log, try different rates.  One to see if the marks disappear and two, how fast can you go before blade rises over knots.
Chuck White
Quote from: Magicman on August 12, 2014, 04:40:16 PM
I agree, if you feed too slowly, it gives the blade time to flop around in the cut!
If you keep the blade engaged in the wood the marks will likely change, maybe even go away!
Yukon, when I have overset teeth I have the band tight on the mill and with the band stopped lightly run a piece of sticking over the band you should be able to feel the errant teeth/tooth. Frank C.
yukon cornelius
sure enough, a small bark packed in the roller. I didn't feel it while running the mill but with it off ther was a small bump at every revolution of the roller. I cleaned it out and will mill tomorrow and see if it fixes it. I need a sweeper on both sides of the rollers and on the back rollers.
That is an item that I mention on here occasionally.  It happens and is easily overlooked.  I forgot to mention it this time.   ::)
At the job I use to have,I would be called if a machine would not run. I would start with the simple things and work my way down. Most times it was the simple things too.
