Drive bearning
Started by rhino135, July 31, 2014, 08:15:34 PM
rhino135
  Just replaced the main drive bearing on my lt 40. How much atf fluid should it take to fill it?
Thanks rhino
drobertson
Never measured it,  I use the sight gage and go with it.  it seems to be near two quarts? just a guess,
POSTON WIDEHEAD
Quote from: drobertson on July 31, 2014, 09:19:58 PM
Yep!
Chuck White
If your mill doesn't have the sight tube, remove the side plug and the top plug and pour ATF into the top hole until it starts to run out of the side hole, then install the side plug and the top plug and you're done!
