Timberjack skidders with Clark 4 spd transmissions...
Started by H.Watts, July 30, 2014, 01:26:59 PM
H.Watts
Hi,
I bought a 1988 Timberjack 380B Graple skidder but the transmission was changed to a 3 spd clark which does not have the output shaft to run the winch.
I found a 1986 Timberjack 450A machine with the 4 spd clark with output shaft.  the shift linkage on the 450 is on the left side of the cab(fuel pump side) and the 380machine is on the right.  the 380 machine is a distance away so am wondering if anyone can tell me if they use the same clark 4 spd transmissions.  I would think they would be the same just different linkage.  Both have 6 cyl cummins engines.  the 450 transmisson has the output shafts on the fuel pump side for grearing.
So my question is will the clark 4 speed in the 450 machine fit the 380 machine?  Thanks.
