Lumber stickers
Started by MIsawyer, July 30, 2014, 08:43:51 AM
MIsawyer
I recently got some 3/4in stickers, instead of the 7/8in stickers i usually use can anyone tell me if there is a big difference in the two of them.  I have heard that there is a significant difference in wind speed through the thinner stickers.
LittleJohn
...your pile will be shorter ???  :D
I want to say all of my stickers are 1/2" thick and about 1" - 1.5" wide; I mostly air dry pine, oak and few other random soft woods.  Also most of my lumber is 1" or 2", not a lot of thicker slabs, but I do the occassial bar top or custom cuts.
drobertson
I've used both, only because of saw job dimensions. Air dried  has shown very little difference (if any), not sure on kilns with fans.
red oaks lumber
3/4 thick is fine, make your sticker wider (1 -1/2 ") that way you can  eassily see the size for stickering. thickness of stickers isn't nearly as important as the stacking and stickering job.
I use two thicknesses.  3/4" for slower drying or non-stain prone species like the oaks, walnut, etc.  For faster drying or high stain prone species like maple and pecan I use 1" thick stickers.
Gray stain is a real problem in this Georgia heat and humidity.
scsmith42
I prefer 3/4" stickers in the kiln, and 1" for air drying.  The 1" stickers allow too much air flow in the kiln, but not as much as I would like when air drying.
Tom's 3638D Baker band mill
GeneWengert-WoodDoc
Almost all stickers are 3/4" thick, with a 1" sticker being used for fast drying softwoods, especially in the South with southern yellow pine.  If you have a wide pile, then thicker stickers are a benefit, but with a 4' pile, a thick sticker only means a bigger stack with less lumber but not faster drying.  With thinner than 3/4", if the lumber warps at all between the stickers, there is a chance the space will be so small that air cannot move easily through.  (Some people use 1x2 pine (actual thickness is 3/4") for stickers...great idea indeed.
