working with green hemlock
Started by hemlock man, July 28, 2014, 06:48:58 PM
hemlock man
Hi folks, new member here, and first time shed builder with limited carpentry experience. I plan on using rough cut full dimension hemlock for the framing. My question is does it need to be air dried. I've been getting mixed input on air drying vs. putting it up green. The framing will be 4x4 post and beam with half lapped corners. The rafters and floor joists will all be full dimension 2x6 hemlock.
I'm having the hemlock milled on my property and would like to get the shed up sooner than later. so working it green (off the mill) would be preferred.
thanks!
hemlock man,welcome to the forum.
I would say no. I built this,
from all green lumber. Mostly hemlock. Most was cut down,brought to my sawmill,lumber sawed and I was building with it within a few hours of the tree hitting the ground. Than I would get another tree and start pounding nails again.This has no interior walls at this time. Just like a shed. Hemlock might split when dry.
GAB
hemlock man:
First things first - WelcomE to the forum.
Personally I would let it air dry Time wise would depend on the weather, and where you are located.  If it air dries some the boards will be lighter to handle and the gap between boards will be less.
Gerald
hemlock man
thanks for the suggestions.
GAB -  is the heavy weight of the green boards a structural concern? As far as the gap between boards, I would expect this to be minimal considering the length of green wood does not shrink significantly after drying (right?). I will be using a kiln dried ridge pole (pine) so this should prevent any separation from the rafters.
Again, rookie here, please chime in if this doesn't make sense.
GAB
Quote from: hemlock man on July 28, 2014, 10:06:21 PM
Shrinkage in the length dimension is usually minimal.
If you are sawing 1" thickness I would not worry about that dimension.
The width shrinkage will vary depending on where in the log the board was sawn.
They say quarter sawn lumber shrinks less than other sawing styles.  I have not experimented with this stuff and therefor can't speak from experience.
Hemlock, I believe would lose a lot of moisture Stack and stickered for just a few months.  This I believe would make the wood lighter to handle, and the gaps after further drying narrower.
Gerald
Peter Drouin
Go ahead and build it right off the mill. :D I do ;D
A&P saw Mill LLC.
License NH softwood grader.
Southside
I have built two barns out of hemlock. The beams and structural timbers were all green, heavy stuff but it worked fine, never twisted, never split, nailed like a dream.  We did a 1" tongue and groove ceiling / floor for the hay loft with dried wood.  A lot lighter, I honestly don't remember if we had any nailing issues or not, and we did not have any splitting issues to speak of.  Now the dry tamarack flooring I tried to lay down.... had to pre-drill about every nail hole.
White Oak Meadows
hemlock man
thanks for advice folks. We're definitely going to start throwing up the frame fast and green. Had the mill over today and zipped through enough lumber in 7 hours  to frame out two 12x16 sheds.
next question, what about siding? I still have ~800 bf of log length. Is hemlock any good for siding? should this be air dried or okay to put up against green framing?
Something else I built,a horse run in.I used 4 inch batten and 10 inch boards. I used for hat for sizing,but still hard to tell size. No air drying for that either.
isawlogs
Put it up green, off the mill. It will be much easier to put a nail through it. Dry hemlock is hard, and harder to nail.
  Nice job there Ray, now let me post.  :D
   Marcel
hemlock man
how about Adirondack style siding with the green hemlock? or would it be best to stick with board and batten to hide any shrinkage
Chuck White
Welcome to the Forestry Forum, hemlock man
The Adirondack Siding should work fine.
As Marcel stated, it nails up easier green, splits when dry if you drive a nail to close to the end of a board.
hemlock man
I'm not sure how to trim the corners if i were to go with the adirondack style siding.  I was thinking of putting a 2x4 on the face of the corner beams to give me something to set the siding into. does this make sense? other suggestions?
Chuck White
Exactly right Hemlock Man!
One 2x4, mated up with one 2x6, then it would be like having 2 2x6's on the corners, and your siding would have them to butt up against!
hemlock man
thanks for the advice Chuck. Do you happen to have a picture showing what you're talking about? is the 2x6 going across the top beam horizontal, and the 2x4 going vertical on the corner post?
