455 Rancher Carb adjustment
Started by ramv102000, July 12, 2014, 06:28:21 PM
ramv102000
Have a friends 455 Rancher here . Carb screws have slots and I don't see any plastic limiters . But the Hi and Low screws only turn a half a turn . Am I missing something or is this normal ?
Randy
JohnG28
They have different limiters. The screw head end is normal but they're in behind it. IIRC you have to push them down towards the body of the saw and unscrew the H and L jets all the way out. You can then take the limiters out and reinstall the jets and springs, sans limiters.
ramv102000
Thank you , would you happen to know how many turns out to start with after the limiters are out ?
Randy
JohnG28
No problem. Start around 1 turn out from lightly seated. That should get it running and be a good starting point.
hamish
Quote from: JohnG28 on July 12, 2014, 10:35:37 PM
Them days are long gone.
Try 2 1/2 on the high and 1 1/2 on the low to start with.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
JohnG28
When I reworked my 350 1 turn out each is where I started and it fired up in a couple pulls. I'm not saying leave them there, I'm saying that will get it running for fine tuning. I don't have any saws off top of my head with even 2 full turns out and they're all tuned well.
NCFarmboy
Quote from: hamish on July 13, 2014, 06:59:04 PM
Sure are.  Had some other Husky models 435 IIRC, Homelites, off the top of my head.
Shep
Lots & Lots of Saws
SawTroll
Quote from: JohnG28 on July 13, 2014, 07:31:17 PM
Neither do I - but a lot of newer models have quite different basic settings, as do some older ones.
You need to know what it is for each model at hand, or sooner or later get into trouble.... ;)
Information collector.
ZeroJunk
I tuned a small Husky for a neighbor. Seems I had to rebuild the carb. I remember scratching my head thinking the high side was still clogged before I found that it needed to be a few turns out. Don't remember the model number.
