6x6 trucks- snagged one and took a pic
Started by Bert, July 10, 2014, 10:23:15 AM
Bert
Anybody have any experience with these? Specifically the military surplus m923. Im looking for a new to me truck to haul lumber locally within 15 miles. I'm trying to make a list of pros and cons. The biggest pro is the access to my mill site. I was locked out for about 3 months last winter due to weather. I could get in with a 4 wheel drive pickup to saw but I could not get a straight truck up the drive due to snow and ice. 6 wheel drive would probably cure that. They seam like a lot of truck for the asking prices. Cons are the short 14' bed and high bed height. Parts may be an issue.
I am not concerned with speed. I realize they top out about 60 mph but the roads I travel are mostly posted with 30- 40 mph limits.
There are a lot of you tube videos and photos but none actually show the truck loaded.
Saw you tomorrow!
StimW
I have driven a lot of the military trucks but got out of the ARMY in 1970.
I don't remember the model numbers but I think you are referring to a Duce-and-a-Half. Called that because they were rated for 2 1/2 ton off road.
I drove the gassers and at the time the new kid on the block was the "Multi-Fuel" .
They were all Bad to the BONE! I went through 8 week Wheel Vehicle Driver course which included off road mud pits and night driving with no lights on.
Like any multi-wheel drive vehicle they will and do get stuck when you ask for too much.
Crazy thing was something in the front end would wind up when you backed up (they called it a Sprag unit) and if you did not pull forward the same distance in first gear it would violently jerk the steering wheel back and forth!
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Bert
I was looking more at the 5 ton trucks vs. the deuce and a half. Same basic idea though from I can tell. Just really want to know if they behave like a truck should or are the all bark and no bite. Seams like the deuces were pretty good
Saw you tomorrow!
Okrafarmer
They can go 60? That's more than I would have expected.
One thing's for sure, even if it's diesel or multi-fuel, I believe you'll go through a lot of fuel for what you get done. As you pointed out, though, if it's a matter of working or not working, due to terrain, it will work for you.
There used to be a big seller of those trucks, and I think they may have been in PA. Naglich's maybe?
Now selling Logrite tools!
mburrow
our fire dept has the M814 extended and yes it will do 60, I think it carries 2500 gal. of water and handles it ok. I ether drive it or a brush truck depending on what we are called out for.
in the M900 series look for a M927 / M928 - Long Body Style as they will have a 20' bed
StimW
I just googled M923 and it looks just like a Duce with single flotation tires.
IIRC the Duce was rated 2 1/2 ton off road and 5 ton on road.
I once slept in the rain in the bed of one with no top, covered with a poncho and laying on my M-14 rifle trying to keep it dry!
New HF Band Mill
Mooseherder
My 53 Deuce will do 60 no problem but I don't have a need to go that fast with it.  I have a Prentice loader on an old logging truck that I would like to transfer onto the Deuce down the road.  It's a fun truck to drive around and a good workhorse.  Mine is a 6 cylinder gasser that isn't bad on fuel.
yukon cornelius
ive driven a few 5 tons in the fire service. I don't know the numbers though. all were diesels. good power, handle pretty well, and get around great. when your stuck, your STUCK! winches available on a lot of them. just a few problems we encountered.... the brake pedal was frame mounted and the cab would shift sometimes wedging against the pedal so you cant push it. fix, cut the hole through the floor bigger. the transfer cases as with any with wear, can  pop out of gear.   when you couple the 2 problems it gets interesting. I ran 75 mph down a curvy one lane gravel hill with 2000 gal of water unable to brake or gear down  :o  lug bolts on one side (drivers side I think) are left handed threads. once in a while they worked loose when off roading.
all around great trucks! I want one! I did hear one time they cant be licensed on the road. I don't know if it true but it might be something to check out.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
mburrow
ours has the 14 liter n series cummins
oros35
Between me and my dad we have a:
1971 M35a2 Deuce and half
1972 M813 5 Ton
and 1991 M923a2 5 ton.
By far the nicest is the M923.  Parts are not that hard to find.  Many of them can be found as a commercial equivalent.  Parts can be expensive, but the trucks are pretty cheap to begin with so buy a couple!  Spare parts! (not much of a market other than collectors and a handful of industries needing a big 6x6 truck!)
Bert
oros, your pretty close to me. Any leads on a good buy? ;)
Saw you tomorrow!
mesquite buckeye
What kind of money are we talking? ??? ??? ???
Some examples here...
http://www.army6x6.net/p/trucks.html
There is one locally for sale, but haven't a clue what they are asking.  Sand color with canopy Conestoga style.
"Looks" in great shape.
BlueRidgeMark
Before you pull the trigger on this, you might want to do some reading on the actual costs.  They have been described as a money pit, a labor of love, and a lot of other things, but I don't think "practical and reliable workhorse" is very often on that list.
http://www.steelsoldiers.com/showthread.php?90811-So-you-want-a-Mil-Truck-here-is-what-they-cost
Not saying you shouldn't do it, but make sure you know what you're getting into.
ozarkgem
I've had 6 deuces's and a few 5 tons. Stay away from the 250 Cummins. Real dogs. No power. If you had a 350 Cummins and a 10 spd I think they  would be a kick ash truck then. I have heard the 900 series are fuel suckers. No experience myself on them. Super singles are the way to go also.
oros35
Quote from: Bert on July 11, 2014, 01:27:24 PM
None that I know of right now.  There was a guy in Delta Pa that I dealt with that had some nice trucks.
Unfortunately, most of the good deals seem to come from the east side of the state from what I've seen.  Closer to the auctions.  All of ours came direct from the govt, at the auctions.  One from Columbus OH, one from Indianapolis IN, and one from Delaware.
And an FYI, just in the past few months, Uncle Sam has taken all the trucks off the auction block.  No more trucks.  A year ago they were plentiful.  Now "0".  Lots of theories as to why, but no answers.
Okrafarmer
Quote from: oros35 on July 16, 2014, 10:49:32 AM
Very interesting.
woodmills1
chevy c5500 is 6 by as well as some of the biggers freightliners.  I have a 4500 6 by and it is a nice truck but may be small for you
Bert
Still on the search for one of these. I have looked at a total of 6 trucks so far but they are all from the same owner. His prices seem high compared to others I have seen. I'm going to check out a different one tonight. Seems like a lot of people collect these but no one actually works them.
Saw you tomorrow!
oros35
There is a pipeline company set up in Zelienople Pa that has a bunch of these trucks in work clothes.  Company is from Texas.  All have Texas plates.  Several tractors, few flat beds, couple tankers.  Right off Rt 19 just north of the town.
There was another pipeline company that was putting in Marcellus shale pipelines down the road from me that had a few too.  Their trucks got abused in the field by the looks of them.
Most of the ones I've seen around here people are asking a premium for them.  That's why we traveled to get ours.
Check out http://www.steelsoldiers.com/ often have trucks listed in the classifieds.
Also try  http://www.kublossurplus.com/ he had a couple hundred trucks last I was up there, reasonable prices too.  Been about 1 1/2 years since I've dealt with him though.
Not sure what part of the state your in.
curdog
I have read emails about the military agreeing to crush the trucks once out of use due to an EPA agreement and emission issues. This has the potential to greatly affect many rural fire departments that use these trucks for emergency response. The FPP and FEPP programs allowed rural departments to get the surplus vehicles to use in wildland fire response as long as they painted it, and put it in service as a fire truck. Not sure if this is why many are not on the auction blocks right now, but I would say this is probably the case.
There is still a lot of discussion about this going on , and things are not completely sorted out yet.
snowstorm
i remember reading something in one of the truck mags saying military trucks did not use any emission controls at all. that is why the feds dont want them used
Mooseherder
The one I got was sold at auction to the guy I bought it from.  It had been used as a water tanker for a local volunteer Fire Dept. before that.  It's life began in the Navy.  I found the Service records behind the Driver's seat cushion. Low Low mileage.  Musta been on an Aircraft carrier. ;D
DeerMeadowFarm
This place has some trucks. The customer's photo pages show some that have been converted to logging trucks....
http://www.easternsurplus.net/customer.html
Bert
I put an offer on an m923a1 yesterday. I am waiting to hear back from the guy. I did some checking on plates , registration etc and no hang- ups that I can see.
Saw you tomorrow!
