Carbide Chains
Started by d1hamby, July 07, 2014, 10:40:51 AM
d1hamby
Who uses carbide chains besides me? I've seen some people talk about carbide coated chains on this forum, but that is not really what I'm talking about. There are all kinds of carbide chains for cutting wood, rescue, filing wood, cutting cinder block and some stone. There are also diamond chains for plunge cutting concrete, but I'm not really interested in those either. I'm more interested in how people use their carbide chains for everyday cutting and how they justify using them. Personally I've found them way more cost effective than steel chains for more of the everyday cutting. I use Pico Duro 3's, a 12" 0.050" 3/8 pitch on my Stihl 130 pole saw and a 16" 0.050" 3/8 pitch on my Stihl 362.
Own a Stihl 362 16" 0.050" carbide and steel, and 25" 0.063" Stihl 020T
Stihl KM131R, 130R and KM56R with several Brush Cutter and Weed Trimmer heads. Pole Pruner (with 10", 12" w/wo Carbide, and 16" bar&chains) , Blower, Modified 135° Hedge Trimmer, Straight Edger, Bed Edger, Tiller Kombi attchment
Oliver1655
Can you post of photo of the chips you are getting from the carbide chain?
John
Stihl S-08s (x2), Stihl S10 (x2), Jonsered CS2139T, Husqvarna 338XPT California, Poulan Microvibe XXV, Poulan WoodShark, Poulan Pro 42cc, McCulloch Mini-Mac 6 (x2), Van Ruder Hydraulic Tractor Chainsaw
d1hamby
I will post pictures of the chips next time I cut some trees and remember to take pictures of the chips. My experience with the Stihl carbide chains is that they are slightly more aggressive of a cut  than the steel chains. The aggressive cut makes thicker chips, but they're not as long, they seem to break apart. The chip size can be changed by adjusting the tooth angle and the raker. Have you seen different results with your chains?
Al_Smith
Carbide faced chain is merely an alternative for people who either don't like to file a chain or are not adept at it .I've yet to see one that can cut as fast as a properly filed chisel chain .
For all intents they have to be machined sharpened and are more costly so there really isn't any cost savings .If you hit a nail with it it ruins a couple of cutters and the chain is worthless .
stihltoomany
I have 2 Stihl Duro carbide chains and I love them. You are correct if you hit steel it will damage cutters. Mine just chipped 3 or 4 cutters. Ran it for days that way. Carbide may be slower than rm chain but I really don't notice it. Cut speed is only one indicator of the time required for the job, I think about the time saw is actually working.  I like it for less experienced operators, they can stick it in the dirt with out any problems. Bring your hand filed rs chain out and cut fence row trees for a couple weeks and then tell me how worthless carbide is. Yes carbide has to be sharpened with a diamond wheel, dealer did it for $12. That chain had alot of run time on it, probably would have dulled a dozen or more regular chains. I tuned the rakers a little and it cuts amazing. Yes its expensive, $54 for 16" .325 i think, that is why I use it on limbing saws. I originally bought carbide for cutting power poles, but liked it so well I started using it for regular cutting. Different jobs, different chains. 8)
Way too many saws, mostly STIHL
Bobcat S650, Bobcat 331 excavator Bobcat A770
and other dirt toys
Looking for hyd bandsaw mill, Timberking used maybe? NOT anymore!
WoodMizer LT40 super
d1hamby
Quote from: Al_Smith on July 09, 2014, 04:30:14 PM
I sharpen all my chains because I don't like the way any of the shops or anybody else has sharpened them.  I mostly use a Milwaukee adjustable speed grinder with a diamond bit, and sometimes a file on the steel chains and the rakers.
I've had machine sharpened carbide chains and I personally like to hand sharpen them. If you hit a nail with a carbide chain you may lose a few teeth but it will keep cutting without any problem. It is not until there are only a few teeth left that it is worthless.
Have you actually used a carbide chain?
BradMarks
I can remember when St. Helens blew, if you didn't have carbide chain to "fight" with all the ash and pumice you couldn't get anything done at all.  They do have their place in certain job sites.
d1hamby
Quote from: BradMarks on July 11, 2014, 04:46:48 PM
Here in FL the sugar sand is everywhere, it is very similar to the pumice. You can't get through very much wood, maybe cutting through 20-30' of wood, before a steel chain needs sharpening.
d1hamby
Here are some pictures:
Andyshine77
The chips/dust, have the making of a really long day. :o
Most chain problems can be attributed to a couple common, and from what I've seen, habitual issues people seem to have with saw chain.
First and foremost, is simply knowing how to properly sharpen a chain. Too much hook and the tooth won't stay sharp long. This seems to be one of the more common problems people have when it comes to sharpening chain. The normal reaction is often to blame the equipment instead of the end user.
The other, and just as common issue. People simply don't know when to stop and give the chain a quick touch up. Instead they just keep cutting. This compounds the issue. The longer you cut with a slightly dull chain, the harder and more time it will take to sharpen the chain. If you don't like sharpening chain in the field, take extra chain with you.
Now I'm sure Carbide chain may have it's place, I'm simply not sure where.
I know people that cut in FL. Unless you're cutting on the beach, the damp conditions are far better than what you'd find in the Midwest, or somewhere like Australia. If you can't make due with semi chisel chain, you're likely the problem, not the chain. IMHO.
Andre.
Al_Smith
To the previous question of have I used carbide chain ,yes .I however do not own any as I feel it is an unneccessary item .Different strokes for different folks.
I did however have a young lady at the Stihl shop try and sell me some for a 200T .The shop owner overheard the conversation and started laughing .He told the  young lady she'd have better luck trying to sell ice to Eskimos than carbide chain to Smitty . :D
Jiles
For what it's worth-----I removed nine large sweet gum trees by digging around with a backhoe and falling the entire tree by pulling with a 4x4 truck and pushing with the backhoe. Since most of you know, sweet gums have a large tap root, and they are difficult to dig up.
I bought a 16" Stihl carbide chain to cut the roots??? I would dig and remove as much dirt as possible, use an ax for the small roots and then cut the larger roots. I soon discovered that my regular chains would quickly dull, as expected,  but could be sharpened.
The problem with the carbide tipped chain, was that the carbide tip would break off!
Yes I know that it was not designed for cutting dirty roots, but I wanted to try.
I even resharpened what teeth were left with a carbide wheel used with my Oregon sharpener.
I ended up just using several chains--used with old bars--- and the scrapping all of them along with the carbide chain, when I finished.
I suppose some people would be satisfied with a carbide chain but carbide can't be sharpened as sharp as a regular chain and, for me, cutting was never as fast as with a regular chain.
Plus, regular chains can be file sharpened where special wheels must be used on carbide.
I would think that it would be difficult to find someone willing to sharpen one.
Satisfy needs before desires
lumberjack48
I used Carlton Carbite surfaced chain for a few yrs when i had a landing man bucking up for me. He could cut up 4 to 5 times more wood before having to put a edge back on. I did the sharping in between felling timber. It would take 3 to 5 minutes to put the edge back on. I hand filed with no issues, files lasted 3 to 4 filings. I never had the points of the cutters break off, that is usually caused by a little to much hook.
cutter88
I don't like them for falling or any logging work, but we use carbide chain when clearing lots because we tend to be cutting low to the ground and around rocks
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
Jiles
stihltoomany
Stihl carbide chain is a specialty chain. If you don't have a need for it don't use it. I have never broken a cutter off as of yet. I only speak of Stihl Duro chain, it has the entire carbide cutter brazed on the link. I can't speak to the coated or other brands of carbide as I have never used them. As i have said it has worked very well for me, but only a couple saws wear carbide for certain jobs. Nice to have choices. smiley_grin
and other dirt toys
d1hamby
Quote from: stihltoomany on July 13, 2014, 03:25:51 AM
The only time I broke a tooth was when I tried to cut up some pallets and was cutting through the nails. The nails broke some of the teeth off but the chain kept cutting. The steel chain didn't cut at all after bumping into a nail.
Hopefully everyone has seen this video:
https://www.youtube.com/watch?v=ooAlNzRwndg
I also put up a new video with a new carbide chain. Let me know what you think.
cutter88
Well the wood in the landing has been to say the least "muddy" the past couple weeks and we buck up our trees with a chainsaw, I Tryed a few different chains over the past few years but Friday I broke down and bought a stihl carbide chaine for my 461... Gonna try it out Monday wish me luck!
Romans 10 vs 9
Piston
I've often thought of buying one of these for my father's MS362.  He absolutely KILLS chains.  I sharpen them for him, and within 20 mins they are done.  He is always hitting the dirt, cutting through dirty wood, and not being mindful whatsoever about trying to keep his chains sharp.  I sometimes look over at him to see a smoking bar from the chain being so dull he is trying to push it through the wood!
Please let us know how you like it, I'm hoping one of these could be the answer to my problems!
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
Hey Piston..
As long as you sharpen them for him, why change..   ;D
SawTroll
Quote from: Piston on July 27, 2014, 06:21:18 PM
With a culprit like that a carbide chain likely won't stay sharp for long either, and it will be a hell of a challenge to sharpen.
Information collector.
d1hamby
d1hamby
I use one for my MS362 and it makes it possible to keep working through the wood even after totally burying my whole bar in the sand.
d1hamby
Quote from: SawTroll on July 27, 2014, 08:56:11 PM
I've never had any problem sharpening a carbide chain in the field with a diamond bit and a cordless rotary "dremel" tool. In fact I think it is easier to sharpen the carbide chains because the teeth tend to not wear as much and it is easier to keep the symmetry the same. My steel chains wear so unevenly that I have to take it back to the machine to get them to cut straight again.
SawTroll
Oh help - the mention of dremel shows me you basically know nothing about proper chain sharpening, only about more or less desperate "stop-gap" measures.......
