Building rollers for around the mill
Started by barbender, June 20, 2014, 12:59:11 PM
barbender
I was thinking of building some rollers with steel pipe and bearings for off bearing, so I figured I would ask if anyone has built any before I try to reinvent the wheel. Would I even need to use bearings, or could I just use a bronze bushing, for instance?
Bill Gaiche
Bronze would work. You would need to keep them lubed on a good machined shaft to get the least amount of friction. Sealed bearings would roll easier and for a long time without needing any attention. bg
Old circle sawmill friend built his rollers using 2x8 oak stringers and glued-up blocks of white oak turned on his wood lathe. The rollers were about 3" diam and 16-18" long. Don't recall what the rod was, but think 3/4 or 1" pipe.
Was cheap and worked very well. Just a bit of oil to lube the wood where the rod went through seemed adequate.
Den-Den
Consider using Delrin plastic to make the bushings from; less expensive than bronze and should work well.
Larry
There is a lot of ways to build good rollers.  You can see pictures of one way in this old thread I did.
rollers
I've made different wood rollers, some with bearings and others with bushings.  I have a couple in the shop that have seen miles of material with hardly any wear and just ride on end grain oak bushings.
You can turn the wood rollers on a lathe or a router table.  The router table is faster for me.
Rollers about 5 or 6" in diameter seem to work the best.  I've made large metal rollers where I've just welded on a end cap on heavy wall pipe.  Welded a short stub axle on the end cap to run in a bushing.
Sometimes factory made roller tables make the most sense, especially if you can find them cheap.
