"rustic" torsion box coffee table.
Started by hackberry jake, June 12, 2014, 05:51:07 PM
hackberry jake
Im using the sour gum wood for this project. Its all 3/8" thick and it didn't dry real straight but other than the top and bottom of the box, every piece is under 2' long. I used long grain and wide grain pieces for the ribs so as not to join long grain and wide grain together (cracking and splitting). I think I will just sand off the clue runs and the high spots and put BLO on it.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
jake
Can you give us an idea what is behind the plan of the "box" and the placement of the pieces?
hackberry jake
A torsion box just uses ribs running in both of the x and y directions. It uses a "skin" on the top and bottom. The bottom will be under tension and the top is under compression. Most torsion boxes are built using mdf or melamine board. I havent seen one built out of real wood so this should be interesting. The design makes an extremely strong lightweight box that resists deflection. As far as rib placement goes... i just tried to put pieces across the glue lines of the skins and use plenty running in both directions.
Very interesting.  I am going to have to study on this.
POSTON WIDEHEAD
i'm not gonna judge it until its flipped over.
Hack's my Dog and I got faith in him! :)
But you said it was a torsion box? Is that one of them boxes where your wife gets in it all twisted up like a pretzel and you poke swords in it?  :D
WmFritz
Quote from: POSTONLT40HD on June 12, 2014, 09:06:35 PM
Kinda like waiting for the curtain to rise!   ;D
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
yukon cornelius
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
hackberry jake
Strength tested the table yesterday.
POSTON WIDEHEAD
It passes the test! You gonna stain it now?
hackberry jake
Probably just a clear finish of some sort
WmFritz
That's no coffee table... that's a stage!  ;D
Well done.
~Bill
Dan_Shade
please let us know how it holds up.
the cross grain gluing would scare me.
lots of dull bands and chains
Nice.
Those are some cool sawhorses in the back with the cedar on them  ;D. A man has to be creative.
hackberry jake
Left Coast Chris
Wow,
That thing turned into a silk purse!  Great work Jake.   Not sure about those test weights you were using though....
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
There, I betcha the test won't be allowed now.
scsmith42
Very cool Jake!  First time that I've seen a TB made that way - very clever.
Tom's 3638D Baker band mill
That is the only sour gum table that I have ever seed.
POSTON WIDEHEAD
 smiley_curtain_peek   .......Shhhhhh!.........$300.00
mikeb1079
Quotesmiley_curtain_peek   .......Shhhhhh!.........$300.00
:D
homebuilt 16hp mill
