drip water system
Started by peterob, June 08, 2014, 07:50:34 PM
peterob
i have an lt28  the water lube for sawing is either to much or off, has anyone got any better ideas so you can adjust it better  thanks
POSTON WIDEHEAD
Can you clamp the hose a little to control the flow?
Ga Mtn Man
I used a PVC needle valve similar to this one:
http://r.ebay.com/KWoEki
You will also need at least one 90° elbow fitting.
delvis
I've seen more than one setup where the person used a 12 volt windshield washer pump to squirt water/lube on the blade.  Wasn't too hard to set up and can be controlled by the operator when he or she wants more water.
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Chuck White
Install a valve to open the water jug to the line, then install a fine-adjust needle valve in the line to adjust the amount of water you want on the blade!
One of those small fuel shut-off valves would work nicely!
I have 2 valves on mine,as chunk says. One to turn off and on and one to adjust the flow.
Andries
Here's my valves - works well, but a lubemizer system would be better.
Hey is Chuck's nickname 'Chunk', or is thecfarm taking some liberty with Chuck White's name? Typo, right?
LT40G25
Ford 545D loader
Stihl chainsaws
Typo guys,just a typo.  ;D  Sorry Chuck. Almost did it again too.  ::)
