Norwood ML26 Help - Need a measurement
Started by Aktundra, June 06, 2014, 08:23:30 PM
Aktundra
I need to build shorter log rests for my Norwood Sawmill. Problem is my mill is 3 hour trip away (drive + boat ride). If someone could tell me what size pipe, I'd appreciate it!
http://www.norwoodsawmills.com/sites/norwood/files/IMG_0613_2.jpg
I'm still loving my Norwood sawmill, but I'm finding ways to make the manual mill easier. Next on the build list is a winch and ramps to pull the logs onto the mill.
This week I worked on planing the flooring and routing the T&G.
I have 60 logs to mill that I gathered this winter. I'm looking forward to getting some work done!
hamish
Can measure the diameter for you in the morning when I get back to the mill.............but have to ask why do you want shorter ones?  Just dig a hole under the post so they can bottom out, much easier than making a new set, if you are running close to the ground.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Lazyguy
Bar diameter is 1.5", 3/16" thick pipe.
The bar needs to be about 11" long.
Aktundra
Thanks for the help!
I need shorter ones because I have the sawmill on railroad ties.
