winch pics
Started by pineywoods, May 23, 2014, 01:34:52 PM
pineywoods
This big ole ramsey winch got dumped in my parts department. Anybody have any ideas where it might have been used, or could be used for ??
yukon cornelius
has the appearance of the winches mounted on the back of old dozers or crawlers. its probably not good for anything so I could help you out by taking it off your hands! just box it up and send it north to me!! ;D ;D those od ramseys are bulletproof! I would make a log dragging setup for my mountainside to get the inaccessible logs out.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Bill Gaiche
Piney, contact Ramsey in Tulsa and they can tell you what it is for. bg
Bill Gaiche
Chuck White
Quote from: yukon cornelius on May 23, 2014, 01:53:42 PM
That's what I was going to suggest.
They can be a real work-horse!
Piney, the best place to use that winch is about 9 miles southeast of Chattahoochee, Fl.  ;)
Larry
I have a similar one.  It came off the front end of an IH Scout used for forestry firefighting duties.  I don't think my wench had ever been used but the shifter was broke and grease dried out.  Cleaned it all up and repainted...looks brand new.
Ramsey has PDF manuals on line.  I needed it when I took it all apart.
Looks like you might be missed a part or two.
pineywoods
Yeah Larry, the outboard shaft support is missing. Wouldn't be much of a problem to fab another one. What's not obvious is the size of this thing. The gear case is over 12 inches across and 6 inches thick. The cable wound on the drum is 3/4 inch dia. Way too big and heavy to mount on anything I own. The 3 point hitch on a large farm tractor would probably handle it ok. I suspect this thing came off one of them big side boom dozers used to lay large piplines. I have 2 smaller ones that came from the same source as yours, front bumper of an old IH scout. one is  now on the back of a small chinese dozer and the other on a big kubota tractor. Anyway, it's up for grabs, just come and get it...
yukon cornelius
if only I was closer id come get it!! nice of you to pass it on!
gspren
Quote from: yukon cornelius on May 29, 2014, 04:04:30 PM
  If I lived as close as you do I'd be on the way!
drobertson
 soak it down and store it till you figure it out, good one for sure,
OH Boy
we had winches that size on the back of army trucks to winch tanks onto a lowboy trailer. two so you could steer it on. wrong color though.
