Unexpected Metal Hit
Started by Board Cutter, May 22, 2014, 10:26:34 PM
Board Cutter
This was the second 12 foot log from a tree.  I had almost finished canting the log when the mill head stopped and the engine lugged down.  When we got done with wedges and chain saws, we opened up the block cut off and found the head from a cant hook/peavey.  As you can see it was completely imbeddded in the tree.  Being the second log from this tree, it would have been about 22 feet up in the tree!!
Best guess someone broke the handle on their peavey and hung the head on a tree.  Over time the tree grew and surrounded it.
TimberKing 2000, John Deere 970, Hitachi Excavator,
They would have had to hang it 22' up in the tree. That would be a puzzlement.
Nomad
Quote from: beenthere on May 22, 2014, 11:31:21 PM
     Doesn't make any sense, does it?  What would you be doing with a peavey 22' up a tree?  Did Paul Bunyan ever do any work around there? :D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
customsawyer
Sounds to me that some one broke the handle out, landed pretty hard on there face in the process, got up and threw it and that is where it landed.
www.thecustomsawyer.com
Cutter, even an elcheapo detector would have found that bad boy. Of course you wouldn't expect it in the second log unless it was a tree house tree. Frank C.
21incher
Maybe a bear stole it from a lumber camp and hung it in the tree for future use.  ;D
GDinMaine
Too bad you sawed into it .  Otherwise just fit a new handle, and you have an extra cant hook.  ;D
Interesting find.
It's the going that counts not the distance!
WM LT-40HD-D42
Ron Wenrich
What's the piece in the upper right hand corner? Where would the hook be attached to that peavey head?  I can't seem to locate it.
Board Cutter
The piece in the upper right corner of the 1st picture is the piece for the hook.  I cut it off as I came into it.  The hook part was gone, and that may be why it was thrown away.
isawlogs
Theres gold in them there logs....  Don't we wish.  :-\
I own two metal detectors and quite frankly, I would not have taken one out to give that log a metal test, I just don't have that much time to waste. Don't rightly know of anyone that would of.
Sure would be nice if one could come up with a reason for that tip to be where it was.  smiley_headscratch smiley_headscratch
   Marcel
Cedarman
With a detector you could probably find the hook which may have been broken near the tree.
Chuck White
Quote from: Cedarman on May 24, 2014, 07:49:00 AM
Maybe it's just hidden inside of a 2x6, completely surrounded by wood!  ;D
kczbest
Seeing what tornadoes can do and where some things wind up after a twister, I would think a tornado could be the possible culprit.
Hail State!
2013 F150 Supercrew 4x4
John Deere 5303 4x4 with FEL
Cook's MP 32
Cat 289C with Bradco MM60 Forestry Mulcher Head
red oaks lumber
as a tree grows in diameter it also grows taller. my guess is the tree was fairly small when that happened, if you look closer the pith isn't all that far from the peavy.
isawlogs
Quote from: red oaks lumber on May 24, 2014, 04:05:29 PM
  It does grow taller, but what ever you put in a tree at six feet when small, will be darn close to the same height at 60years down the road, a tree grows from its tip and not from its stump.
The tornado is a very pausable cause in a case like this. The handle may have roted off a lopng time ago.
   Marcel
clww
Maybe it fell out of a plane? ;D
Many Stihl Saws-16"-60"
18-Wheeler Driver
Dave Shepard
I'm pretty sure that one is the last wooden handled one I broke. I threw it so hard I think it went back in time.
RPowers
Wow, neat find, though I'll bet you weren't thinking that when you trashed a blade!
One nice thing about the hardwoods I cut is that a piece of metal that big would've stained that log for 4' in both directions. There isnt any stain at all in that log.
2013 Woodmizer LT28G25 (sold 2016)
2015 Woodmizer LT50HDD47
red oaks lumber
marcel
thanks for the explanation, i didn't realize they grow from the top only.  :)
Ron Wenrich
I wonder when the last time it was that they had a twister in Washington state.
Quote from: red oaks lumber on May 24, 2014, 08:23:23 PM
marcel
ROL,
If that was true, your cattle fences would be reaching for the sky  :D.
ST Ranch
board cutter - do you know the history of the stand of trees where the tree came from?  I am wondering if the site might have been hi-lead [overhead cable] logged at one time in the past and the peavy got caught up in the carrage rigging or something, when yarding in a turn or returning empty?
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
red oaks lumber
danny
up here we use fence posts not trees :D :D
isawlogs
 Glad you use fence post, I have found my fare fair share of fencing inside of trees. Not always before sawing into them  >:( :o >:( ::)
   Marcel
Quote from: red oaks lumber on May 25, 2014, 11:54:46 AM
danny
:D :D :D
And, the trees love you  ;D.
