-processor heads-
Started by BargeMonkey, May 14, 2014, 03:51:15 PM
BargeMonkey
 Been trying to figure out how to pick up production, and getting there slowly. Wondering if any of you guys are running the Rolley or Hytek heads. Im not looking to go true CTL, but drop and 90% fulltree limb and top. Been thinking about a stripper, which may happen but exploring ideas. Im looking to cut, delimb and pile with the Timbco, so no ones bothering with a saw, grab go, drop and back. Will a rolley full tree delimb big hemlock and smaller hardwood ?
Southside
Barge Monkey,
With all the nice gear you are obtaining I have to ask if there are any job openings in your other career field.....
White Oak Meadows
barbender
Once you get that far you may as well go CTL and be done with it, IMO. It's a lot of screwing around trying to limb whole tree with a processor head, if you are running it through you might as well buck it to length and pick it up with your new forwarder ;)
barbender
I forgot- you already have a forwarder- all the more reason to buck 'em at the stump.
deastman
I've found that it doesn't work well trying to delimb treelength in the woods with a processor,  it takes less room to cut it to length and forward it out. Your best bet to increase production with what equipment you already have would be to add a stroke delimber with a topping saw.
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
BargeMonkey
Quote from: Southside logger on May 14, 2014, 06:41:59 PM
Barge Monkey,
I just took a new job, for a local company in NYC. They are hurting for qualified people, deckhands make out here. Kinda rough work but I think my deckhands making 400+ a day. The mate and I are the lower paid ones by industry standards.
BargeMonkey
Quote from: barbender on May 14, 2014, 07:10:04 PM
The problem is, where I log isnt forwarder friendly, few guys do it but mostly in softwood. Only reason im wondering is a rolley will bolt right on, but they arent cheap. Have to just break down and buy a 501HD now.. lol.
Big Rooster
One of my cohorts does this on his Tj 2628 with 762C head.  He makes it work well and sends them through tree length parallel to the skid trail and then skids with his high track cat.  With a forwarder you are correct in that you are fairly limited in ground.  Do you currently run them through tree length with your fixed head?
BargeMonkey
 I have lateral tilt on my barsaw head, which is handy. I can knock alot of the bigger limbs off, and if you take your time can top and stack basically all of them. We tend to hand cut anything over 24", or the good stuff. Im just trying to figure out how to jump up without adding a big expensive head or stroke delimber, which then makes my skidders and loader not big enough. Its one big expensive cycle.  A remanned rolley with a computer is 125k from woodland in MI, and if im going that deep then I need a Timbco with minimum 260 hp. It doesnt end. Figured maybe a low hour take off and dont bother with the computer.
1270d
Not sure you can run a rolly without a computer
barbender
Have you been around any 6 or 8 wheel forwarders? I'd say they can go anywhere a skidder can. Side slopes are the limiting factor, but I haven't seen any hills that can't be forwarded if the processor cuts it right. You guys in other areas have more rugged terrain than northern MN does, but we have some fairly wicked glacial hills in areas.
BargeMonkey
 There are a couple guys around doing more forwarder work, but every once in a while we get to go pick one back up.  8)
Yeah down the road I can see selling my 230 and going for a 564. Cut to lenght is cleaner,  I wont dispute that. Biggest problem with a true CTL "team" is the cost, your well over 1 mil, for decent low hour stuff. Im going to talk to Lakeshore and see about a Rolly, thats where my machine came from.
ga jones
I was at the state college show last year. There was a company there from benezette pa. Steep rocky terrain. 100 percent mechanized. CTL said they forward everything backwards from the bottom straight up to the top of the mountains.The harvester works 60 feet around the skid way.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
barbender
You should be in brand new stuff for that money. You should have a really nice low hour, say around 8000, for around $400K. You could get in for a lot less than that. I'm not claiming that CTL is the solution to everything, but I wouldn't be afraid of it based on hills or mountains. There are Ponsse teams working in Montana and the PNW, a lot of harvesting is done in Europe in mountainous terrain and I haven't seen anything but CTL in everything I have read about from over there.
Brleclaire
For what your doing your better off with a feller buncher and skidder setup. Processer and forwarders can work steep terrain but its the timber type also you have to consider. Out west or in Europe they cut alot of conifers but if you are trying to process hardwood of any size your production goes way down. Most processing heads aren't designed to handle crooked and crotchey wood. I've talked with a lot of processor owners who say once branches get over 2-3" in hard wood your not going to get very good limbing and stuff starts to break real quick.
Make sure the forwarder has enough power for hills. The logger that cuts my land had a forwarder that did not have a bigger enough motor.Did not like hill,not enough power to take a full load. One job he was on he was taking ½ and ¾ loads.
BargeMonkey
 Ive been adding equipment as I go, the push to go true "ctl" would be if it was just me alone. Alot of these woodlots im on are small, 8-12-20 loads of wood. Had just the 440D and 450G until about 4 years ago. I got that timbco because shes low HP, I guess even 260 isnt enough for the high production guys now. I was just about to buy a Hytek head, and someone talked me out of it, I guess they arent what the owner claims. I like the idea of a barsaw, tilt and the stroke head, would be ideal in my application. Its either pulp, super lowgrade and firewood or real nice, nothing in between around here.
barbender
Depending on the GPM of your pump, 260 HP should be plenty to run many of the processor heada like s out there.
Corley5
My Fabtek's 125hp running the four roller head.  No lack of power.
BargeMonkey
Quote from: barbender on May 16, 2014, 09:30:30 AM
Ive got 175hp. 6068T deere engine. It was a built that way, only seen 3 others. Most 415's had a 6.8 or 5.9 cummins. I dont mind it, and doesnt eat much fuel. Has processor package and a seperate saw pump for a disc saw.
barbender
Even 175hp should be enough for some heads, look at Corley's Fabtek 4 roller. He's probably cutting similar timber to what you are.
Bobus2003
Something like this maybe, complete, nice unit without new price..
http://www.bhtimber.com/used/2004-7000-log-max/
Corley5
  A couple guys just down the road took the plunge and went from a newer TimberPro with a Rolley and 1010 single bunk JD to new JD stuff.  A 703? with a Waratah head and double bunk forwarder.  About 725,000 dollars.
Ken
BargeMonkey   My 608 only has 160hp but works fine as long as I don't try to make it do things it wasn't designed for.  Your forwarder will also work on some pretty steep hills without issue.   In areas that are too steep I use my cable skidder to yard trees to a flatter spot where I process them.
BargeMonkey
 I dont lack for power with my Timbco, and like you said, if you run it as designed. I was under the impression you needed 260 to run a Rolley efficiently. My 230 was a starter machine, ive gone thru it and she works good, at somepoint I plan on trading it for a newer 6 wheeler. Problem is alot of my jobs are nasty, steep and full of rock. Forwarder gets run alot doing private road work, or I did a job 3 yrs ago where the header was 1 mile back in the woods, piled and stacked it out roadside. I listen to and appreciate everyones opinion, this forum is a great tool. Im slowly building a fleet, of paid for equipment and once the time comes that I dont wanna tugboat anymore I can go cut wood fulltime.
