Got one
Started by goose63, May 11, 2014, 01:21:00 PM
goose63
After trying to be care full I got my first log dog  :-[
goose
thank you to all the vets
VictorH
Well you are a true sawyer now :)
I bet you checked them things for a looooooong time too. First time you forget,  :o  Was a good blade too,right??
drobertson
 8) 8), I thought "what is he talking about dogs for?" then it hit me, barely missed one yesterday myself,  it happens, and will again,
Dave Shepard
I got one yesterday, as well. It must have been Log Dog Day. :D Actually, I just tickled the bolt for the roller, but that should count for something. ;D First one on this mill, and only the second ever.
Dan_Shade
I eventually sawed the bolt off on my first roller :)
lots of dull bands and chains
goose63
Yep try to keep a eye on em and new blade to :-X
goose
Delawhere Jack
Hit the top of one of the manual stops yesterday. :-\ Went about a year without sawing the mill. It seems to only happen when there is a big crowd watching..... :-[ Then I nearly rolled a log on the mill with the clamshell clamp up.... One of the kids helping was kind enough to warn me though.
21incher
I got my first today also and then got it again for good luck.
JB Griffin
It took me around 8-9000 bdft but I finally got my first one last week with a brand new blade with only one cut through a 12ft log. >:(
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
hacknchop
Ive cut up a few it happens! Biggest rookie mistake was sawing a big old pine admiring the funny bluish color of the wood and couple boards later pow hit something took a look at it, was a bullet just lead so cut some more till pow, hit the nail they used to hang the target!!
Often wrong never indoubt
Brucer
I have two saw marks on the second manual side stop. The top one is about 1/16" deep and the lower one is about 1/8" deep.
I was talking to a customer a few weeks back and his Dad was poking around the mill, trying to figure out how it worked. He spotted the cuts and kidded me about being careless. I said (with a straight face) that the stop was too tall so I was trying to cut it a little shorter. Did it first with a dull blade and didn't get very far so I put a new blade on and tried to get all the way through on the next pass :D.
There's actually 3 years between the two cuts, but it makes for a good story ;D.
PS: There are NO saw marks on my clamp.
PPS: I tried, but it's too hard.
Bruce    LT40HDG28 bandsaw
I have showed this one before.  One layer of the log turner has been sawed off.
No, I did not do it.  It was done by the previous sawmill owner.  Bet it made sparks !!
Chuck White
I tried that one once, Lynn!
Just got done turning an awkward log and it was in perfect position to cut, only problem was I forgot to put the turner back down!
Well, it was a very bright and sunny day, but the sparks that came off of that turner/blade connection was a lot brighter than the sun!  :-[  ::)
The off-bearer just took off behind the log pile when he saw that it was going to happen!  I just thought he had to go or something, until ^&&%%%$.
Didn't much more than take the paint off, but left a good mark and cost me a blade!
dboyt
Hate when that happens!  There's two kinds of sawyers... those who will do it, and those who will do it again.  Usually, it is when I'm distracted, as when people are watching.
