First Thread, Noob be nice
Started by resqd1, May 09, 2014, 09:46:00 PM
resqd1
Tried searching but not sure what to search for. Wondering thoughts from others, been lurking a long time but finally made an account. I am thinking about a bandsaw mill. I have a low budget for one, or in my wife's words no budget, but that is another discussion. Anywho, I have seen some saw out there made with rubber auto tires for the drive wheels instead of a big steel wheel is this a bad thing or something to shy away from?
Me and My Stihls
drobertson
 If you really want to saw, I would suggest making an envelope and stashing away cash, and getting one that has support and works without too many issues, no need to upset the apple cart,  times are tough for many folks, a throw together could be fun for you but back at the house might be a different story, it is at times with a pretty good working mill.    jmo
Hello and Welcome to the Forestry Forum, resqd1.  Your sawing future really depends upon whether you want to saw a few logs and make some hobby woodworking lumber or whether you might want to develop a sawing business.  Your location, log availability, sawing/lumber market, and your personal ability are all key factors.
resqd1
I appreciate the advice, truly, still I don't think my question was addressed, or it was and I didn't understand the answer. Is rubber auto tire wheels for drive wheels bad? Like Turner Mills uses, or just find one with steel wheels like sequoia or hud-son etc. I don't think I will be able to stash away enough for a woodmizer or norwood. Unless someone has one that needs a pickup truck and they want to trade but I don't that right LOL. So auto tires ok or no?
Me and My Stihls
resqd1
Side note I am not sure all the uses, it will start as hobby stuff for my woodworking
Then maybe go other places from there
Me and My Stihls
I did not offer an answer because I have never built or had any experience with a homebuilt sawmill.  Be patient, someone will come along.
That looks like a nice table.   :)
resqd1
Turner mills are not a homebuilt unit? I am talking ones out there, I am not looking to build one. Thanks for the info though, I appreciate it.
Me and My Stihls
drobertson
There's no doubt that much can be sawn with these units, no doubt,  keeping the wife happy might be a different story,  a mix of emotions for sure, lumber can be made a many of ways,  the work, and cost in another story,
resqd1
Oh and thanks for the kind words on the table, it is 9x4 and cut from a ponderosa pine that burnt in the Telegraph Fire in Mariposa California.
Me and My Stihls
mikeb1079
i would think that a small manual mill would be perfect for you.  you can saw enough in a weekend to keep you woodworking for a long time.  i wouldn't shy away from a rubber tired mill i've heard they work just fine.  i've heard good things about several small manufacturers on here, better yet would be to find a member near you that has one and you can see it in person.
homebuilt 16hp mill
resqd1
How would I find members near me? Thanks for the input?
Me and My Stihls
By clicking on the "member map" above.  It is huge, so give it time to load.
Adding your location to your profile and to the profile pin map will help others to find you.   ;D
resqd1
Soo cool thanks I will ad my location if I can figure it out
Me and My Stihls
hackberry jake
I have pondered tires as band wheels before. If I were building one, I would use tires with a heavy crown, like motorcycle tires. I have heard of peole using trailer tires and it removes the set from one side of the band over time. This has been overcome by cutting a groove in the tread where the teeth land, but I think I would still prefer motorcycle tires. You should be able to find a few either on CL or your local metal recycling business.
hackberry jake
Maybe some of those little donut tires that come with smaller cars as spares... Wonder what the diameter on those is?
Ljohnsaw
Quote from: hackberry jake on May 09, 2014, 11:44:13 PM
I'm building a mill using donut tires.  You can get them in a range of sizes.  My deciding factor (besides the band width) was I got one for free.  Mine are 21" so I bought some 1-ΒΌ" bands.  They do have quite a crown and run at 60+ psi so they are pretty hard.  I don't expect the blade to crush the crown and take the set out on one side of the blade.  Time will tell.  I'm 90% done, just need to stop messing around with my 900 other projects and get er done! :D :D
John Sawicky
octam1
you are only 30 min from me, you are welcome to stop by and check out what we have going on and you can see a WM in action... I dont get a whole lot of time on the forum these days but you are welcome to contact me... I have sent you a pm with contact info...
KnottHead Custom Sawing & FabWorx
Ceres/Twain Harte CA.
WoodMizer LT40SHDG38 w/AS2 & Debarker
Lucas 8-20 Swinger w/60" Slabber & Planer
Solar/Dehumidifier Kiln in the worx
Stihl - 2x 026's, 044, 046, 2x 066, MS660, 2x 088 & 3x 075AV
Well, dia of those "space saver" spares is the same as a normal tyre for whatever car it's off.  Otherwise you would drive on a lean when you had to use it.   ;)
I'd suggest that rubber types are not as good as proper metal wheels.
BUT, if you have to buy a set, and the shaft / bearings, and the engine, and all the steel... Then it's probably going to cost more than just going and buying a new mill. Woodland, EZ, even a hobby size Woodmizer.
On the other hand, if you are the DIY re-use / recycle type. Now you can pick up some used car wheels /tires/ hubs from a junk yard. A good working engine from some place. Re-use some steel. Now you can build a useful "hobby"sawmill, that actually works just fine, for only a fraction of the price.
ozarkgem
Doesn't one the factory resaws use tires for wheels? Seems like I saw an ad for them and they had the tires on them. I think it was Red in color. A local guy made one with tires and sawed up 2 houses with it. Seems to be lots of them out there. You can buy 18" pulleys for about 45.00 each new.
Chuck White
Personally, I've only ever seen one mill that runs the blade on rubber tires and that was made by Simplicity.  Seemed to do a fine job of sawing and that was at the Woodsmens Days in Tupper Lake, NY.
resqd1
TURNER Mills is one company that does, there is just one for sale out of Oregon that I was thinking about looking into but the price seemed high compared to maybe picking up a used Woodmizer 15
Me and My Stihls
kelLOGg
You've got that beautiful 4' wide table which looks like it was cut by a slabber and you live in the land of big trees. Have you considered getting/making a slabber?
dgdrls
Welcome aboard  Resqd 1
Does your Screen name reflect some Fire Service work??
This may help a bit with your question
https://forestryforum.com/board/index.php/topic,73194.msg1107035.html#msg1107035
Best
DGdrls
hunz
Welcome to the forum!
  I wish I had the gumption to take on a diy band mill. I unfortunately am not a design artist, and completely rely on my WM to make me look like one!  I am sure the ones on here that have homegrown mills are glad they did take the time to fab one up. One question I would pose, what do you intend to use the mill for 5 years down the road? I think that may help you decide if you want to go homebuilt or save up some money first for something that you know WILL work. All band manufacturers are not created equal, even though someone who has built many created it. My first mill could hardly cut air straight, the first time I saw an lt-50 run, my life long manufacturer match had been made. I am not trying to sway you any particular way, ALL of the forum sponsors make a quality mill. Just keep in mind that my first mill, was #325 of a manufacturers production output, and I always carried my whole toolbox to the mill with me. My hat is off to the FF members who have homebuilt mills that cut straight lumber!
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
resqd1
Yes it is a play on words as I am a firefighter so the rescue portion of the name, as well as I am a Christian and have been Rescued myself.
Thanks for all the other input guys.
In regards to my table, it was done on a chainsaw mill at my buddies place. It is not a solid slab.
Me and My Stihls
