272 xp tuning
Started by dgdrls, May 04, 2014, 09:49:28 PM
dgdrls
Picked up a 272xp a while back.  could not get the old carb to run well.
Got a Bailey's replacement and I can get the saw to idle well
and have been working on the High end tune.
Trouble I have and I suspect it may be more than tuning is
it will not pull well in a cut with any kind of down pressure.
As I recall cold compression was 140-150 range (will recheck)
Air cleaner is good, new plug, fresh mix.
any thoughts or tune tips before I take it to an expert??
DGDrls
JohnG28
Between 1 and 1 1/2 turns out from lightly seated is normal. Somewhere in there should give you the right tune if all is well with it.
LeeB
I'm far from a chainsaw expert but, have you checked the chain? Could the rakers be a little short?
CTYank
Chain sharp, really sharp?
Then I'd check fuel filter, fuel & pulse lines. Try it with a known-good plug.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
