S10 grapple skidders are they any good ?
Started by logman81, May 04, 2014, 09:27:24 PM
logman81
Just wanted to know if they are a good skidder? Found one and wanted to know the ins and outs with them.
Precision Firewood & Logging
treeslayer2003
wish i had one. i like the last IH skidders.
logman81
Can any one give me info on them? The one I'm interested in has a 6 cyl cummins, 23.1x26 tires chains on all four, loaded front tires. Has a esco grapple and gearmatic winch but contrôlée needs to be rebuilt.
logman81
Do you think it would be a up grade from my 230 tj?
Reddog
Sorry I don't much about them.
The advice I can offer is to check on parts availability for any thing IH branded. Some transmission and torque converter parts are getting down right rare.
So it would make me wonder what axles are used and what parts are available there also.
With the motor being a Cummins that is easy enough.
logman81
From what I gather parts can be had on the later ones. Don't know to much about them but I've heard they were pretty tough skidders .
treeslayer2003
Quote from: logman81 on May 05, 2014, 11:34:28 AM
an s8 would be an upgrade.
i have never seen one with a cummins but you could put any engine in them. late models used a funk powershift driven by a jack shaft off the fly wheel. JD owns funk now. axles will be eaton or rockwell.
komatsu dealer should be able to get parts.
Dave Shepard
There were many engine options in the IH skidders. Detroits, as well as many D and DT series all the way up to the DT466. ;D
logman81
This machine is a '83 model year so it probably is a funk power shift. I contacted the owner but have not heard back yet.
treeslayer2003
Quote from: logman81 on May 05, 2014, 06:16:56 PM
send it to me  ;D it would look good next to my s8. 1980 model.
logman81
Can you tell me anything about the international skidders specific to  s10 treeslayer? Are they a good reliable skidder? I don't know much about them.
treeslayer2003
Quote from: logman81 on May 05, 2014, 07:15:24 PM
i can only assume the s10 is a bigger version of the s8. i have a s8, it has been a great machine. pulls much more than most like sized skidders. the gearmatic has been the worst thing about mine. having four skidders, i rotate the cable machines, if the gearmatic sits a few months new bands will be the cure.
the rest of it has been great. the 358 IH engine has been bullet proof. i do need a charge pump but it has many hours......i estimate over 10,000.
logman81
Yes the s10 is bigger then your s8. I'm wondering if this would be a good up grade from the 230d?
logman81
Finally got ahold of the guy he is going away on business but will be back by the weekend so I will get the details then. I'm the meantime if any one has any other info them please share.
logman81
Well I've got my jack for sale will see what happens!
Nemologger
I would be carefull about getting rid of that Jack. Every s-10 I ever saw had the transmission out of it.
Clean and Sober
logman81
Thanks nemo, I'm also considering one of the members timberjack 450 grapple skidder nothing set in stone yet.
barbender
How are you going to use a big grapple machine on the small thinnings that you cut?
BargeMonkey
Quote from: barbender on May 07, 2014, 07:36:45 PM
Yeah a grapple will move more, but your going to smash alot more, and fuel. Mine drinks fuel. A grapple is really only efficient when grabbing a pile of stems at once, if your trying to grab 1+1+1 all over your going to wanna scream.
BargeMonkey
The machine your looking @ has 24.5's ?   Did the guy with the forwarder ever get back to you ? Yeah a grapples nice but takes some serious getting used to.
barbender
I guess I'm just confused-if you are looking at going with a forwarder because a cable skidder does too much damage, how is a grapple going to solve your problems? Anything the cable skidder gets you in trouble for, the grapple will much more. Just sayin'.
logman81
No the guy with the forwarder is taking to long. The grapple is a better solution for me. Not all of my jobs are small thinings. Some are clear cuts for horse pastures and house lots. I'm not worried about smashing some stuff. A good operator will keep that to a minimum I think. I've run grapple skidder many times before infact I ran a machine identical to the 450 when I was younger it was a friend on the family's. So I'm quite familiar with how to properly run grapple skidders. Sometimes you got to take a good deal when it comes along. All my competition is or is converting to grapple skidders around here almost all of the hand fell for a grapple machine.
logman81
Well I did the deal for the grapple skidder, thanks for your help guys!
treeslayer2003
you got the 450? i would love to have seen that s10.
logman81
Yup went with the 450, just trying to figure out trucking. Yes that s10 is nice to but can't beat inclosed can with heat.
