HM 126 New Guy
Started by WillWarner, April 29, 2014, 09:48:16 AM
WillWarner
I have no experience in sawing other than that last month or so.  I had 40 or so eastern red cedars die this last year and decided I was going to build something out of them so I bought an HM 126 from Woodland Mills.  Mill and all works really great I have cut several hundred boards but I am using up blades terribly fast.  At least fast in my opinion.  As I have said I have no real experience other than just diving in on my own and now I am looking for help and knowledge as to why I am using blades.  I maybe have 10 to 15 hours on the machine and have used 6 blades. Any ideas?
Ephesians 2:8-10
WillWarner,welcome to the forum. I have no idea about red cedar,but the cedar I have will dull a blade faster than other trees. How are you getting the logs out of the woods? Dragging them on the ground will put a lot of dirt on them. I peel my cedar this time of year.
Sixacresand
Welcome to the Forum, WillWarner.
MAI
WillWarner,
Welcome to the FF.
WillWarner
I dont really drag them around much mostly pull a trailer up along side of them and since I dont have a tractor i pick up one end at a time by hand and wrangle them up on the trailer then haul them to my pile.
Ephesians 2:8-10
Hello WillWarner, and Welcome to the Forestry Forum.  Yes, if you are talking about ERC, it will dull blades faster than most anything else, but not at the rate of a blade per hour.  If the blades are dulling then whatever your are sawing is dulling then, whether it be the Cedar, or dirt, or ??
hackberry jake
Smaller mills will use blades faster than larger mills as well for a few reasons. 1. You have less band length. The longer the band the more teeth to take the wear. 2. You have less horsepower. Higher HP mills have enough power to push a dull blade further without bogging the engine. 3. Sometimes smaller mills are rated for less pressure on the band pulling it tight. The tighter the band the straighter it will cut once it starts getting dull. Beggining sawyers will also try to recover everything they can out of a log as well, meaning more cuts through the bark to save that 2x4. Sometimes you are better off leaving the waney 2x4 in the slab as far as band wear and time spent.
backwoods sawyer
Next time you go to change a saw take a good look at how the saw is tracking on the wheels and how the saw is positioned at the guides. If it is running back on the wheel the wheel will push the set out of the saw and it will act like it needs to be changed even tho it is still sharp and it does need to be changed so that the teeth can be reset.
Just something to take a look at ;)
Backwoods Custom Milling Inc.
WillWarner
Thanks for the information fellas
Ephesians 2:8-10
JamieT
Welcome will! I also own a hm126. Make sure your guides are properly set, and blade tension is tight! Ive sawed up a ton of cedar so far and I feel like blades last longer on cedar. These guys been doing this a lot longer than I have! Cedar is really popular for people building fence posts  are you hitting metal? Sometimes you cant see anything until you hit it. Also take it slow, when I first started sawing I wanted to push thru as fast as possible. I learned to slow down real quick! Post some pics of your set up! These mills run great when they are set properly.
Learned just about everything I know, from the greatest man ive ever known. My father! Everything else was self taught thru the school of HARD KNOCKS ;-)
WillWarner
Have you had problems with your blade wheel belts?  I was running what I thought was proper tension and the belts began to deteriorate and it seemed like they were being crushed into the wheel groove; pinching out the top and tearing them up.
Ephesians 2:8-10
JamieT
No I haven't had any trouble. I thought I wore out a belt but a quick call to Neil and I was corrected. Make sure your running plenty of water. If you dont, the blade can heat up and possibly melt the belt. When you open the doors to the mill, how much of the blade is sticking out? Thats important to. The band should be flush with the back side of both wheels. You should have about 3/16th of the teeth sticking out the front. Close up pics would really help.
hackberry jake
If the band gets too hot to touch, you have a problem. As the band heats up, the metal expands and makes for a loose band that will take a dive on you (or a rise).
HaroldSiefke
I to have a woodland mill - frankastine...oh a little modified . I was told when I bought my mill not to buy one unless I bought the stuff to sharpen the blades. It was good advise. Good luck and happy milling :-)
Harold
Sodrawdy
HaroldSiefke, What did you buy to sharpen the blades? I have the HM126 and most blade sharpeners Ive seen cost as much as the mill.
