If you have wavy boards, check your blade tension gauge for accuracy.
Started by DGK, April 28, 2014, 11:23:38 PM
DGK
After 4 years of trying to troubleshoot why I was getting wavy boards in wide cuts, I have finally solved the problem. I borrowed a blade tension gauge (Starrett - saw tension gauge) from Wood-mizer and compared the borrowed saw tension gauge to my hydraulic tension gauge that is installed on my mill. It read between 300 - 500 psi difference. Now, I crank my tension up to 3000psi and and no more wave even on 24" wide cuts. :-)
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
VictorH
Do you plan to replace the gauge on the mill or just keep it turned up?  Thanks for the tip.
giant splinter
roll with it
drobertson
Nothing like knowing for sure! Never hurts to double check, in this case sounds like you nailed it.
dboyt
Hitting a nail is usually a bad thing when sawing, but I'm glad you nailed it.  Do you go with more tension for thicker blades?
5quarter
DBoyt...I occasionally run .055"s and find that they'll run straight with a little less tension and still give me the benefit of the stiffer blade body. Others with higher HP mills probably run them with the same or greater tension with good results.
Blue Harbor Refinishing
DGK
I inquired about any possible damage to the machine from running higher than recommended blade tension and was told that there is little risk. I have never broken a .045 band but have broken the .055 with regular or lower tension. For now, the 7 deg 1.25 with standard set is working great.
Doug
Yukon, Canada
Dave Shepard
I was told when the mill was delivered to pin the gauge at 3,000. Seems to like it just fine.
DGK
3000psi and sometimes over, is where I am running it now. According to the Starrett saw tension gauge, 3000 is equal to about 2600 on my mill.
Doug
Yukon, Canada
Larry
I've checked several with my gauge.  Most mills are off some, to a lot.  Doesn't seem to be brand specific either.  Its something that needs to be checked, possibly on a annual basis.
My TK won't tension 1 1/2" bands to factory spec but on the good side it doesn't seem to make a difference.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Dave Shepard
On WM mills, make sure the two chrome rods are lubed properly.
Dave Shepard
Two rods and one piston.  Anyway, I have three shiny things to squirt.   ;D
YellowHammer
Quote from: Magicman on April 29, 2014, 01:52:14 PM
smiley_thumbsup
Two are out in the open, the third is kind of hard to get to, just behind the others.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
backwoods sawyer
My gaudge only only goes to 120 lb I grease the zert daylie, give it 16 turns and run it at 80 psi ;D zero shiny rods to oil ;)
Backwoods Custom Milling Inc.
highleadtimber16
Wood-Mizer told me today that higher tension reduces the chances of cracking and blades breaking. I just can't wrap my head around that theory. Anyone else been told this??
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
CalebL
Quote from: highleadtimber16 on April 30, 2014, 01:33:16 AM
Yes.  Will at the Missouri branch has told me repeatedly to crank up the tension on the blades.  Less problems that way.  I have been doing this for 2 years without any problems.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
backwoods sawyer
my manual calls for 60 psi woodmizer recomended that i go as high as 90 psi when I was truoble shooting a tracking issue, (bad idler arm pivot bearing) i settled in at 80 psi. Haven't lost a saw to craking in a quite a while.
Dave Shepard
The manual says nothing about squirting anything on the piston. That would be like going around and oiling all of the rods on all the hydraulic cylinders. :)
OK, but hydraulic cylinders retract and keep the piston rod oily.  The piston rod on the blade tension does not and is always exposed to the elements.  While I am squirting two, I just do three.   ;D
