Stihl chainsaw flywheel keyway
Started by markkelly, April 25, 2014, 08:23:49 AM
markkelly
Has anyone ever had the molded keyway break off and file agrove into the flywheel and plsce a steel keyway in plsce.
Thanks,
LT 10 Woodmizer, Stihl, Husquvana,wood carving tools, Ford 3000 Tractor, Trailer.
Jiles
Quote from: markkelly on April 25, 2014, 08:23:49 AM
Thanks,
I have never did that, but if it were me, I would just replace the flywheel without the key.
Crankshaft and flywheel taper is what secures the flywheel in place. The keyway is for alignment.
You must insure that the tapers are in perfect shape and clean.
I would mark the key location on the outside flat surface near the outside edge of the retaining nut.
With this method of attachment, you must insure that the crank does not move while tightening the nut.
Satisfy needs before desires
ladylake
Stihl should be ashamed putting something made that cheap on a saw..   Steve
sharkey
Mark,
The keyway is only there for alignment purposes.  The taper of the joint between flywheel and crank is what holds the assembly together.  Make sure the flywheel and crank are clean where they mate - no oil.
joe_indi
Quote from: sharkey on April 27, 2014, 12:53:49 AM
Mark,
Mark, this is correct. So if you want to save some money, mark the position of the molded key on the flywheel, align it with the groove on the crankshaft and press it into position and tighten it down.  If you want to be doubly sure, clean the shaft and apply a light film of adhesive on it before sliding the flywheel into position. I have done this on numerous saws and brushcutter flywheels and I am yet to see one that has moved out of position.
