Smokin' H bridge
Started by petefrom bearswamp, April 14, 2014, 11:39:06 AM
petefrom bearswamp
Sawed for 1/2 hr this AM when the head would go down but not up.
error message check cable connections which I did then called WM.
Tried a couple of other things Barry suggested, then when I tried to raise the head smoke poured out of the H bridge box.
Ouch.
$650 plus shipping.
So far this spring I have had a gross sale of $350.00.
Glad i don't have to rely on sawing for a living.
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Chuck White
Pete, is the H-Bridge part of the computer on your mill?
You're right though, good thing you are not dependant on the mill in order to put food on your table.
pine
When I was doing my mill research I ran into what looked like at the time a plethora of H-bridge failures that folks were reporting.  I don't know if there was a batch from the manufacturer that had problems but heard/read about a bunch of failures (quite expensive ones) and since have seen very little about failures of the H-bridge.
This is the first one in some time that someone has posted about.
Sorry for your troubles Pete.
Ga Mtn Man
Sorry to hear of your rather costly trouble.  How many hours on your mill?
stavebuyer
We went through one a couple weeks ago. Bearing going bad in the drive sprocket got the drive motor one day and the H-Bridge the next. I have been through several H-bridges and each time it was the end result and not the root cause. Bad connection on the power strip or a bad bearing in the drive system will burn out the H-Bridge.
ladylake
Any way to put a fuse or circuit breaker before that H bridge that would pop before it does.  Steve
petefrom bearswamp
Mill has 650 or so hrs on it.
WM Hannibal  didn't have the part but Marty Parsons in PA does.
WM has always been very good about timely shipping so maybe it will get here tomorrow.
Barry at WM said to be sure the contact strip and bottom rail are clean.
How about the part that contacts the strip. It appears to be spring loaded and the hydraulics and forward /back drive all work.
I think maybe my helper over lubed the head drive chain and some may have gotten on the contact strip.
I did a cursory cleaning of both this PM and will do a thorough job tomorrow.
The bottom rail appeared dirty as the sandpaper i used loaded up with junk, but my thought is that with the weight of the head having some pressure on the lower rail wouldn't that take care of any dirt/crap on it?
Steve I don't know if a C B  can be done but I can't imagine that WM engineers wouldnt have placed  one in the circuits if possible.
Hey Chuck how come you  aren't sawing on such a nice day?
Pete
Kubota 900 RTV
Ocklawahaboy
I know the electronics are big time savers and one reason some of you can turn out many times the BF that I can with my old manual mill but there is something intuitive that says circuit boards on a big machine that lives outside and spits sawdust are set up for failure.  It seems like they would keep the electronics as simple as possible.
stavebuyer
That button under the bottom rail needs to be clean and making good contact too.
The bearing issue can be a little sneakier. The H-Bridge will handle the spikes of dragging back a large cant but not the heat from continuous resistance in both directions when a bearing fails. A circuit breaker or fuse would be constantly tripping whenever you dragged a cant off the mill.
Ga Mtn Man
I don't understand what the contact strip has to do with an h-bridge failure.  Isn't the hydraulic pump(s) the only thing powered through the contact strip?
petefrom bearswamp
Good point Ga mtn man
Thanks stavebuyer.
Oklawahaboy I sometimes wish I had kept my old hydraulic non computerized mill
Especially for a late life hobby.
Kubota 900 RTV
barbender
I think the H-bridge is bypassed in reverse, when I smoked mine on my '97 the reverse still worked.
dgdrls
Quote from: petefrom bearswamp on April 14, 2014, 05:15:45 PM
Thanks stavebuyer.
When I was considering a new mill, WM in Hannibal had a hydraulic
converted LT-28 which, as I understood at the time,  was purpose built for the Amish
as a Demo unit.
I'm certain you will be back running in no time Pete.
best
DGDrls
stavebuyer
Quote from: Ga Mtn Man on April 14, 2014, 05:08:14 PM
You are right that the contact strip is only supposed to power the hydraulics. When there is a bad connection the power sometimes finds an inconvenient path through the H_bridge,
Peter Drouin
And can go though A bearing and burn out the grease out of it.
A&P saw Mill LLC.
License NH softwood grader.
Chuck White
Thanks stavebuyer.
Want to trade!  ;D  :o
Quote from: petefrom bearswamp on April 14, 2014, 03:35:09 PM
Pete
Just finishing up sugaring!
In a couple of weeks I'll be out there, at it again!
backwoods sawyer
Sand your rails and oil with ATF, clean the contact stip and contact (park off strip to clean) clean and sand the ground this will allow the bearing to turn with less resistance and insure the ground takes the path of least resistance.
Backwoods Custom Milling Inc.
Brucer
An easy way to fry and H-bridge is to reverse your carriage down the track and then bump it back into forward while the carriage is still moving. As the carriage is still coasting backwards the motor becomes a generator. If you put it into forward just then, you'll be trying to push current backward through the H-bridge.
The bypass diodes are supposed to provide some protection by conducting reverse voltage around the H-bridge. Doesn't always work, though.
I used to build H-bridge controllers for small hobby motors and I came up with half a dozen ways to toast them.
Bruce    LT40HDG28 bandsaw
petefrom bearswamp
thanks everyone
Backwoods where is the ground?
Barry at wm said the bottom rail.
Is this it?
Pete
Kubota 900 RTV
Dave Shepard
There is a pad that rides on the bottom rail. I was just looking up at mine yesterday as I was aligning the mill. I really don't like laying on the ground looking up at a machinery anymore. :D
drobertson
It will be bolted to a small assembly, it has springs just like the one that rides on the contact strip.  Saw dust can interfere with the springs at times causing them not to push the contactor firmly against the rail.
petefrom bearswamp
I wish that when i bought my mill and the salesman was going over the operation, he had included some of the tips regarding routine maintenance and cleaning contacts etc.
Maybe this stuff is in the manual I will have to check.
But thank you all for the info.
Pete
Kubota 900 RTV
backwoods sawyer
The logs we have been milling have a lot of pitch so while I was oiling the rails this morning I wanted to watch the lower rolls to make sure they were turning and noticed the ground was flipped off the bottom rail, it springs right back. I keep an eye on it when the sawdust and sticks start getting deep.
YellowHammer
Quote from: Brucer on April 15, 2014, 02:31:17 AM
Great tip, I was wondering why those diodes were there.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
petefrom bearswamp
H bridge came yesterday, too cold to work on the mill.
In the package is a sheet with 14 steps to follow when replacing.
I did find a technical service bulletin from 2011 which had several maintenance steps to do and did them then, but have failed to keep the bottom rail and grounding block clean.
Hard lesson learned.
Pete
Kubota 900 RTV
