I know it's odd...
Started by Jeremysdad, April 14, 2014, 01:20:23 AM
Jeremysdad
But really? A 1 year old weed-eater won't run on fresh gas (with oil and Seafoam, and I drained the tank last year and ran the carb dry)???
My local store here sells 100% gas...which is what I use in my small engines. (They were 100% gas in all 3 octane levels, guess I didn't drive enough!!!)
It's a Homelite, ftr.
It'll run most of the way up at half choke...and if you flip it upside-down, it'll run all day long. Plug looks brand new.
I'm out of ideas.
Jeremysdad
I do realize that this is a 2-stroke forum. :)
Rob5073
I have a Homelite weedeater also an it was the hardest starting, weakest running weedeater  I ever owned.  I switched to an Echo and haven't had any issues since.
ladylake
Not much quality left with Homelite, mac or poulan any more and the Epa makes them set the carbs lean and a lot cant be adjusted .   Steve
jargo432
So does the EPA make Stihl set up their saws lean?
Jack of all trades.
Jiles
Quote from: Jeremysdad on April 14, 2014, 01:20:23 AM
I'm out of ideas.
Regardless of what brand, or octane of gasoline or brand of oil, motor will not operate correctly with a stopped up carburetor. Even the tiniest grain of dirt in the right place in a carburetor will give you fits. There are many ways contaminants can enter your fuel system.
I would suggest a thorough cleaning of all fuel related items, mainly the carburetor.
Satisfy needs before desires
Jeremysdad
Thanks for the ideas.
I took it off yesterday and sprayed it out as well as I could. Further testing determined that it runs best upside down.
The Home Depot was less than helpful, so I am either going to cut slots in the mixture screws so I can adjust them myself, or suck it up and take it to the local small engine guy. I hate to buy a new one, but with as cheap as it was, it's not worth throwing parts at, and a new carb is 30 bucks (can't find a kit for it).
breederman
Did you check to make sure the primer bulb is not cracked? They don't last long and can cause those symptoms.
Together we got this !
67L36Driver
More than one chainsaw, weedwacker, leaf blower or whatever won't run after the first seasom as lean as they are set.
Remove the limiters on the mixture adjustment screws and give 'em a half turn and try it again.
The EPA has Waaaaaaaaaaaaaaaaaaaaaaaaaaay overstepped their mandate.
Over 40 old magnesium runners.  Plei Trapp Valley Duck!!! Club.
petefrom bearswamp
You are spot on regarding the EPA (especially poor agency)
My small Husky the model of which I cant remember doesnt have any slots in jet  screws
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Jiles
Quote from: 67L36Driver on April 14, 2014, 04:57:58 PM
Ever wonder why most new equipment requires 50-1 oil/gas mix.
I consider this to be an EPA thing and I usually run all my equipment on 40-1.
Of course the oil is so much better then it was years ago and that could certainly be a factor.
Jeremysdad
Further follow up:
Used a bullet connector that was tight enough to turn the mixture screws, got it running a lot better. Needs some fine tuning, but it will run with the choke off now. In fact, it runs better than it did when I bought it last Spring.
Thanks for the help! :)
ladylake
Quote from: jargo432 on April 14, 2014, 02:40:06 PM
If a company has quite a few 4 stroke engines that run real clean then they are allowed to set their 2 stroke engine a little richer just so all they sell balance out.  Company's like Homelite  might not have any 4 stroke engines and end up having to set their 2 strokes too lean.   Steve
