When is a Rod not 16.5 feet? Surveying Info
Started by pappy19, April 09, 2014, 06:06:27 PM
pappy19
When Is A Rod Not 16.5 Feet?
(More times than not)
By
Knud E. Hermansen P.L.S. P E., Esq.
The science of geometry and mathematics is exact. The infinite depths of stellar space are measured with such exact nicety that the position of stars and planets can be calculated to the fraction of a second of time. How can it be that in the ascertainment of one line of so small an area, bounded by four lines only, a difference of from 8 to 24 feet arises? It is evident that the methods pursued, and not a defective science, have brought about the different results, different maps." Warren v. Boggs 90 W.Va. 329, 332, 111 S.F. 331 (1922)
As experienced title attorneys and paralegals know, measurements along the same boundary vary between old and new surveys. At first impression there does not seem to be a logical reason for the sometimes large disparity between the measurements found in the deed and the modern surveyors' measurements. Consequently, litigates and the surveyor's client have the impression that the surveyor is at worst, incompetent or at best, negligent in surveying the historical boundaries, adding or taking away land. The fact is that most times differences in the measurements do not reflect any change in boundary location or the addition or loss of land. Variations between old and new measurements are, in fact, common and should raise questions only if there were no differences. Nevertheless, clients and litigation involving property boundaries frequently require a rational explanation to help explain the difference between the measurements cited in the records and more recent measurem ents.
"The science of mathematics is exact, but the different results reached in its application by different surveyors, is sometimes startling to the layman, when applied to what appears to be an ordinary survey." Zirkie v. Three Forks Coal Company 103 W.Va. 614, 626, 138 S.E. 371 (1927) quoted from, Warren v. Boggs 90 W.Va. 330 (1922)
The original surveys of lands in the older States of the American Union were exceedingly deficient in precision. This arose from two principal causes; the small value of land at the period of these surveys, and the want of skill in the surveyors. The effect at the present day is frequent dissatisfaction and litigation. Lots sometimes contain more or less acres than they were sold for. Lines, which are straight in the deed, and on the map, are found to be crooked on the ground. The recorded surveys of two adjoining farms often make one overlap the other, or leave a gore between them. The most difficult and delicate duty of the land-surveyor is to run out the old boundary lines.... Gillespie LL.D., Civ. Eng., W.M. Treatise on Land-Surveying Comprising The Theory Developed from Five Elementary Principles: and The Practice with the Chain Alone, The Compass, The Transit, The Theodolite. The Plane Table c. D. Appleton and Company, New York (1881)
To comprehend the basis for the difference, knowledge of the surveyor's duty and some historical information is required. The surveyor's duty in regard to surveying historical boundaries is often described as following in the footsteps of the original surveyor. Unfortunately, searching for footsteps involves searching for recollections, markings, monuments, and records that typically range in age from 50 to 300 years old. The intervening time has taken its toll on this evidence through decay, fire, flooding, construction, unintentional destruction, deceit, ignorance, and the unavailability or incompetency of reliable witnesses, to name a few.
"But old surveys are not to be so tested. Most perfect in the beginning, they are constantly undergoing change and decay, until by wind, fire, rottenness, and the acts and frauds of men, their evidences lie only in memory and hearsay." Kenizedy v. Lu&'ld 88 Pa. 246 (1878)
Monuments referred to in deeds are often perishable; as trees, wooden buildings, or fences, or slight and temporary as a stake, or a stake and a few loose stones, intended to be supplied by something of a more permanent character. They serve to point out at the time, to the parties in interest, the bounds of the land conveyed. After these monuments are gone, and such a period of time has elapsed, no one can be found who remembers to have seen them, or can testify as to their location. Uniform continued occupancy by buildings, fences or other equivalent indications of ownership is evidence that the land was located according to the original monuments. These monuments perish; and time sweeps away those who could point out where they stood...." Cutts v King 5 Me. 482, 487 (1829)
To further compound the problem, preventative or curative actions were prevented through ignorance, denial, or the seemingly prohibitive costs associated with surveying. As a result, the deed descriptions so often copied for one conveyance to the next are seldom as reliable or unpretentious, as reliant parties would hope. The following is a brief explanation for some of the many errors and inaccuracies in older measurements.
Equipment Precision: The equipment used during the early surveys was not as refined or precise as modern survey equipment. The typical equipment used in early land surveys consisted of a compass and chain. In some rural areas this equipment continued to be employed up into the 1960s. The typical compass and chain was seldom able to obtain measurements better than the nearest 1/4 degree (15 minutes) in direction and nearest link (7.92 inches) in distance.
                           0                         ¼ Mi.                        ½ Mi.                                         1 Mi.
Distance
Angular                      16,500 ft.              5,280 ft.                  1,650 ft.               1,000 ft.                                    500 ft.              165 ft.
Uncertainty               (1000 rods)                                          (100 rods)        (10 rods)
10°                             2887.1                     923.9                           288.7               175.0      87.5                    28.9
1°                                  288.0                      92.2                            28.8                  17.5**     8.7                                          2.9
30¢                                 144.0                      46.1                            14.4                    8.7        4.4                                          1.4
15¢                                   72.0                        2.3 .0*                        7.2                    4.4        2.2                                          0.7
1'                                      4.8                        1.5                              0.5                    0.3        0.1                                          0.0
30²                                    2.4                        0.8                              0.2                    0.1        0.1    0.0
15²                                    1.2                        0.4                              0.1                    0.1        0.0                                          0.0
1²                                     0.1                         0.0                              0.0                    0.0        0.0                                         0.0
The error caused by a 15 minute deviation in direction is shown by the figure. A 15 minute deviation in direction results in an error of 23 feet per mile. * Similarly, a 1-degree deviation in 100 rods results in an error of 17.5 feet. **
Figure 1
The typical compass did not have magnification and only a rudimentary method to measure the slope (if at all). The limitations of the compass were well known among the early surveyors and members of the bar. The magnetized needle frequently lost its magnetism or was subject to changes in the magnetic pole or variances caused by electric storms, the Aurora Borealis and nearby magnetic attractions (local attractions). In some cases, metal shavings or impurities were found to reside in the brass compass housing that drew the needle off along certain directions.
The chain, the other piece of ancient survey equipment, was heavy and unwieldy. It was difficult to suspend without introducing considerable sag. Links soon stretched, became bent, and were clogged with debris or kinked, adding to the uncertainty of measurements.
The adoption of the vernier transit and much lighter steel tape by many surveyors in the late 1800's and early 1900's allowed practitioners to measure directions to the nearest minute and distances to the nearest 1/100th of a foot, every 100 feet.
(Compare this to modern equipment which can consistently measure angles to the nearest second and a distance (as far as visibility permits) to the nearest hundredth of a foot using the newest equipment, such as satellite receivers. Visibility between stations is no longer a factor.)
Practitioners: The training and skill of some past practitioners left much to be desired. Rigorous training and formal education for surveyors was haphazard or nonexistent. One or more surveyors seemed to practice in every locale where their only attributes seem to have been a sense of direction, hemp rope or consistent pace and a passable talent to draw lines. Their practice was questionable and would amount to fraud by today's standards. Licensing, which was intended to remove the charlatans was not mandatory in many states until the later half of this century. Even after licensing of surveyors, many licensing requirements did not require a test or proof of skills before issuing a license to practice.
Assuming the surveyor had the minimum skill and knowledge, the help the surveyor employed seldom did. The surveyor arriving at the site with a trained, or semi-trained, field crew was almost unheard of in the past. Help was more often then not the client and men hired from the local population. The surveyor or a trusted deputy who generally operated the compass or transit supervised a survey crew in the early days. The remainder of the survey crew (on a large survey) consisted of two chainmen hired from among the local population, two or more axemen to cut and mark the line, a cook, and a cook's helper to clean utensils and help pack supplies. Training of the chainmen was rudimentary at best and left much to be desired in the resulting accuracy of the distances.
It was not error for the court to call the attention of the jury to the fact that defendant's measurements were made by a "baker attended by a tinsmith under the supervision of a lawyer." This is not such departure from judicial gravity as to call for a reversal.
Omenstetter v. Kempei6 Pa.Super. 309 (1898)
Terrain and Site Conditions: Present day practitioners and landowners sometimes fail to remember what the terrain and site conditions were like at the time of the early surveys. Virgin timber several feet in diameter, both standing and fallen, presented formidable obstacles to thwart the surveyor in measuring a straight line through the forest. Hostile Indians, foreign powers seeking control of the wilderness, squatters not interested in paper title, wild animals, disease, and lack of shelter and nutritious food took their toll. Under the circumstances, surveyors were more concerned with their surroundings and well being than their measurements.
The difficulty of making an accurate survey by courses and distances, under the conditions obtained in that country at the time this survey was made, were very great. It was a rough heavily timbered country, making it hard to see between stations, distant from each other, and slow and irksome to chain directly from station to station, but it was comparatively easy to select accessible points for corners, and practically guess at the courses and distances. To this we must add the circumstances that there was then a mad rush of speculators into this region for land at two cents an acre, and consequent pressure upon the surveyors, well calculated to induce resort to the easiest and quickest method of achieving results." State v King 64 W.Va. 546, 579-580 (1908)
In the wilderness, in which those early surveys were made, it was practically impossible to avoid mistakes. Winding Gulf Collier Co. v C2inpbell 72 W.Va. 449. 471 (1913)
Even after the virgin timber was removed and the land settled, the surveyor's ability to measure accurately was hampered by dense growth brought on by the now abundant sunlight and rich soil on what had once been shaded forest floor. Blazes once made to mark the boundaries were lost when the timber was removed or decayed. The present twenty-minute drive to the courthouse took a day or more in the past on roads were which were muddy paths or covered with snow or debris. As a result, records were not always obtained and the previous measurements for the property and measurements for the adjoining property were not always compared before recording a new description or map.
Land Values: Many attorneys continue to use the same description written a hundred years ago. This practice not only fails to uncover latent problems but ignores the law of economics. The same parcel worth several hundred thousand dollars today was frequently purchased for pennies when the last survey was performed. In the past, the cost of having the land surveyed may have been more then the price to purchase the land. Under these conditions, speed was more important than fastidious measurements. The carelessness that caused the omission or overlap of a few acres at ten cents an acre was not worth the twenty-five cents required to resurvey and correct the error. The landowner purchasing 400 acres was not concerned with overlaps or a deficiency of a few acres. Needless to say, a deviation of a rod or two on a measurement would not have caused any concern whatsoever.
Procedures: The procedures employed by early surveyors leave much to be desired by today's standards. Old survey texts are filled with suggestions that were generally unknown or ignored by the early survey practitioner. Surveyors were cautioned that frequent use of the chain would inevitably cause the links to stretch and eventually require the surveyor to remove a link or two. The surveyor willing to achieve measurements accurately to a few feet was advised to avoid measurements using the compass at certain times since the compass needle tended to vary by a few minutes during these periods of the day. Deviations caused by the shift in magnetic north over time and location were ignored even though the error amounted to several degrees in some cases. Instructions packaged with new compasses were quick to warn the surveyor to hold the chain away from the compass, periodically sharpen and adjust the spindle, and relieve the static electricity that built up in the glass.
When, however, the glass becomes electric, the fluid may be removed by breathing upon it, or touching different parts of its surface with the moistened finger. An ignorance of this apparently trifling matter has caused many errors and perplexities in the practice of the inexperienced surveyor. Gurley. W & LE. A Manual of the Principal instruments Used in American Engineering and Surveying W & L. F. Gurley, Troy. N.Y. (1878)
Problems were so prevalent and generally ignored during surveys conducted in the early and mid 1800's that legislation was passed in many states requiring surveyors to periodically check their chain against a known line and note the deviation of their compass from a known meridian. Even the otherwise cautious surveyor was sometimes unaware of problems caused by iron ore deposits or other localized attractions sufficient to pull the needle off during a reading.
Ignorance of proper procedures or the speed necessary to survey large tracts in a short time resulted in paper surveys (i.e. protracted lines) or surveyors pacing, using stadia or slope chaining rather than making time consuming horizontal measurements.
The error resulting from measuring on the slope rather than a horizontal distance is shown in the above figure. At a 6% slope and distance of 105 rods, a three-foot error will occur. The steeper the slope or the longer the distance, the greater the error.
In some cases distances were estimated and directions approximated. In other cases haphazard corrections such as adding "one rod to each score" for slope measurements were applied in an attempt to compensate for crude practices.
It appeared that at the time this survey was made, an excess of ten or twelve per cent had been allowed by the surveyors in other parts of the lines of said township.... Heaton v. Hodges 14 Me. 66. 67(1836)
But the experience of the Courts has shown, that excess of a measurement is so uniformly indicated in surveys of that early period, the Court is not prepared to say that the excess, which was proved in this case, was evidence which would warrant the jury in drawing an inference of fraud. Machias v. Whitney 16 Me. 343, 348 (1839)
The practice of actually running the boundary rather than traversing around the property forced many early surveyors to measure across obstacles or estimate the breadth of the obstacle rather than go around it. As a result, estimations were frequent. At other times chains were laid on top of obstacles or the chain curved around the obstacle rather than measuring the straight-line distance between them.
Area which is a product of the direction and distances can be no better than the worst measurement. As a result, the area which is frequently of most concern to the layman is subject to the widest variations and exaggeration.
The acre of that day, as is and was well known, in the locations made in this State, was larger than the exact acre. Bussey v. Gran4 20 Me. 281, 286 (1841)
Blunders: In the past, just as today, surveyors were prone to make mistakes. Early cases document many blunders that were discovered sometime after the survey.  It was not uncommon for the surveyor to lose their tally (the count of the number of chain lengths), transpose numbers, deviate from a straight line, misread the compass and chain or make a miscalculation.
Old surveys were often inaccurate; and mistakes were often made in copying their descriptions into the patents leaving out lines and putting north for south, and east for west. They were also made in copying those descriptions into subsequent conveyances. Winding Gulf Colliery Co. v. Campbel4 72 W.Va. ~449, 467-468
In some ways, errors were more likely to occur in the past than today. The literacy of the population in the early days led to many errors traceable to poor grammar, lack of formal education and spelling.
The descriptions in deeds are usually prepared by surveyors who compose the calls with reference to the lines as they exist on the ground. Surveyors are not informed of, or concerned with, the fastidious refinement in the use of language favored in some courts."
MacCorkle v. C'kyofc7harlesto4 105 W.Va. 395, 402, 142 S.E. 841 (1928)
"Remoteness, land values, habits and education of the people did not tend to promote accuracy." State v. Hicks 76 WVa. 508, 510-511(1915)
Other errors were a product of the time. Many of today's practitioners will no doubt attest to the fact that the invention of the typewriter was a welcome invention and prevented numerous errors previously caused by interpreting poor handwriting, smudges and faded ink. The pencil and paper taken for granted by the modern practitioner and used to record information and jog the memory were rare and quite valuable in the past. The ink bottle and quill pen used by the early practitioners was not easily used in the field. The early surveyor was attuned to using knots on a thong, notches on wood, or sticks in a pouch to keep track of measurements. The slide rule and calculator which has eased the burden of tedious calculations and removed the cause of many math errors was beyond comprehension at the time most surveys were performed. All calculations were done long hand. (Today, the concept of Total Stations is invaluable. Total Stations is the use of a field computer to track each measurement).
This article is a brief summary of the many sources of errors in old measurements. A particular locale or name of an early surveyor may offer more particular reasons for differences. The attorney or paralegal, no less than the surveyor, should keep these facts in mind especially when interpreting descriptions where directions are stated to the nearest degree or fraction of a degree and distances to the nearest rod or fraction of a rod.
In closing this report, it may not be improper to call attention to the fact that the various litigations and disputes about boundaries, which our courts of justice are constantly called upon to decide, are most of them either directly or indirectly the result of the present loose and imperfect method of conducting land surveys. This evil is not; however, it must be acknowledged, confined exclusively to the surveyors. Many of our lawyers, who are entrusted with the drafting of instruments of conveyance, are often deficient in the knowledge requisite to render their descriptions of land correct and to place them beyond the possibility of a misconstruction. Variations of the Magnetic Needle, Report of the Commissioner on the Variations of the Magnetic Needle, State of Maine, p. 74, 1866.
Compliments of:          Knud E. Hermansen
                                     Surveyor, Civil Engineer, & Counselor at Law
                                     R.D.2, 1955 Poplar Street
                                            Old Town, Maine 04468
                                            Phone: 207-827-6187
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
dgdrls
Mr. Hermansen is well respected in the Land Survey field.
He is a great speaker and writer.   I read his articles whenever I find them.
DGDrls
pappy19
I really loved reading this paper and hope to see more of his writings in the future. T.S. Madson II is another great surveyor and brilliant mind. He wrote "The Ultimate Zero Sum Game" a LLS Publishing book that is out of print but can be had sometimes on Amazon.
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
dgdrls
http://surveyorconnect.com/index.php?mode=thread&id=183480
probably one of the best short "survey" papers I have read.
Johns Little Acre by L.M. Powell.
DGDrls
pappy19
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
coxy
was that 1.625 a     it was hard to read but interesting  ;D thanks
Brucer
I figure just about every issue he discussed applies to my land :(.
Bruce    LT40HDG28 bandsaw
kwendt
My husband is a land surveyor.... This article is spot on for the landowner. This gentleman is highly regarded by other engineers, surveyors, and legal professionals throughout the U.S. We just bought 78-87 acres in a metes and bounds state (Maine) last surveyed in the 1900's. This property will be surveyed properly this winter... So that we will finally know what we've actually bought... Lol. And yes, we are employing a fellow Surveyor and Mapper to do the work... As it's frowned upon to survey your own property these days! Laugh...
87 acres abandoned northern Maine farm and forest to reclaim. 20 acres in fields, 55 acre woodlot: maple, spruce, cedar and mixed. Deer, bear, moose, fox, mink, snowshoe and lynx. So far: a 1950 Fergie TO-20, hand tools, and a forge. (And a husband!)
