My HF Track Extension and first cuts
Started by StimW, April 07, 2014, 07:40:03 PM
StimW
I wanted to be able to mill 16' wood so I built a trailer frame with an extension for my new Harbor Freight Mill.
I only wanted to move Mill around my property so the axle just sits under the frame so I can remove it and put the Mill on the ground or wood ties.
I got some oak logs and some smaller scraps so I have been practicing on the scraps.
The piece on the Mill was pretty rough but I cut a 2" slab off of it.
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Looks good. I bring my logs to the mill. I have no wheels under it. That is what I wanted,works good for me.
Looking good.  When you are sawing with the wheels on, you will need some stabilizers or blocking under that center of the mill to keep it from sagging.  Logs are heavy.
Small Slick
That looks great!  The addition of a trailer brings a new ease to running the mill. If you add 3 jacks to each side then it will be really solid and stiffer. I have a similar set up. I use the last two jacks and the hitch jack to get it level then support it with the other four.
Nice mill.
John
YellowHammer
Looks like a first class fabrication job.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Small Slick
Yellow hammer is the one who taught me to level with three jacks.
John
goose63
Make sure the jacks in the middle are out far enough so the head will pass by I found out the hard way now I have to cut them off add a piece of 2x4 tube put the jacks back on your mill head looks like my wood land
good looking job 8) 8)
goose
thank you to all the vets
justallan1
Nice job. I like how the bunks are higher than the carriage rail, it would make a great place and easy job of making hold down clamps for traveling. Slide a tube through a bunk and clamp it to the carriage. Just an idea.
Allan
21incher
Looks good. By raising them up it sure makes it a lot easier on your back.
drobertson
Nice job on the extension!  That looks like it will work out great,
StimW
Thanks everybody, it helps to have a Fabrication Shop!
It will have to be on the ground for anything long and heavy.
New HF Band Mill
goose63
My trailer is 22 feet long with 6 jacks and the tires on the ground it should hold heavy logs ( I hope) will find out in time :)
goose
