Must be Spring...
Started by wannaergo, April 07, 2014, 06:35:56 PM
wannaergo
found a soft spot on the edge of the swamp today, and it tried to swallow the machine.. took a bulldozer and a ponsse harvester to pull it out.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Peter Drouin
Nice Cat 501, I bet you can put up a lot of loads in a day with that. 8)
A&P saw Mill LLC.
License NH softwood grader.
Corley5
Southside
Saw a guy do that once in February with a similar sized machine, only the results were much different.  By the time it was all said and done a week had passed, somewhere north of 30 loads of logs had been pushed under and around the machine, and a whole about 100 yards across had been dug, it was really, really, ugly.  The insurance company even had a guy there seeing if the head could be removed as that was the only part above ground, they contemplated leaving the carrier there.  Ended up just having to replace the starter and one planetary before she was back in the woods.
White Oak Meadows
sawguy21
 :D :D :D It is definitely that time of year.
wannaergo
Yeah, its a nice rig, seems to do ok.. 40-50 cords a day. we were pretty lucky, it only took a couple hours to get out.  I've decided I hate spring. got stuck again today  ::) the woods road is so shot that we can barely get in with our pickups and the prehaul truck quit hauling.. now we have about 300 cords that can't get hauled. whens summer?
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Ken
Glad you got it out without too much grief.  Unfortunately this time of year requires a fair bit of stockpiling for those of us without deep enough pockets to take the time off.
1270d
good thing there was someone there to help.  I'm thinking the caribou would have had a tough row to hoe by itself.  Has anyone mentioned that it saves a lot of time just not getting stuck? :D
Corley5
There's easier ways to clean out the cab  ;) :)
petefrom bearswamp
Thats why here in central NY I always shut the guys down until mud season passed.
The jobbers bitched but the clients were happy and the ground was Ok.
Also no damage to the jobbers equipment.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
NS logging
I don't disagree with you, but sometimes the clients don't want the weekly stumpage checks to stop up here
clww
Last three Mondays that's all we've been battling here-MUDD! I make it a "four-letter-word". Pump water out away from the work area, move the pump, repeat. >:(
Many Stihl Saws-16"-60"
18-Wheeler Driver
