The sycamore removal project
Started by VictorH, April 06, 2014, 09:51:37 PM
VictorH
We have a large - perhaps huge sycamore tree that we decided needed to come down.  It stood about 85' tall.  I forgot to get a photo before I began to limb it.  The first step was to remove the tree house my oldest son and I had built some 10+ years ago.  Forum rules say no pictures it didn't happen  :D  - so here goes
The trunk measure 46" across the small point and 53" across the wide.  I used a Husky 455 rancher with 18"bar  to do the limb work and a Stihl 460 with a 24" bar to take the trunk down.
Dave Shepard
You need to get that guy quartered and on the mill. 8) I see that one is pink in the middle. I had two sycamore logs turn pink, after they were sawn, even the sawdust turned pink.
VictorH
I do plan to saw up that butt log.  I've already sawed two limb logs off of it.   ;D  Most of the limbs were too snaky so they are firewood.  I've got to order a ripping chain to break down that log to get it on the mill.
This was the main reason for taking it down.  This was about 45-50' up on the main trunk.  The roots were doing a number on the sidewalk as well.
Is that a lift in the second picture that you used for the limbing?
VictorH
Yes that is my tow-able lift - Simon RZB55.  Has a 55' reach.  Got a steal of a deal on it several years ago.  Paid a liquidation company $990 for it As-IS. Had to go to San Antonio Tx to pick it up, replaced the tires 30 minutes after hooking up to it and when I got it home had to clean the carb and replace a 12 volt high throttle actuator.  Last year replaced the tired 11hp Honda and actually had to replace a 20' hydraulic hose during the removal.  Was sure glad the extension ladder reached the bucket when it blew.   :D :D
Stephen1
A great tree project.
As my brother Inlaw says...if we don't need to work on it ...why would we buy it.. 8)
5quarter
bump.
   So lets hear the end of the story... ;) Pics of the lumber?
Blue Harbor Refinishing
customsawyer
You don't have to get a ripping chain just to cut it in half. Ripping chain cuts a little smoother than regular chain but the regular chain will cut a little faster. Or you could just file your regular chain really close to 0°.
Nice log.
www.thecustomsawyer.com
