which end of the log do your start with.
Started by ozarkgem, April 06, 2014, 08:00:17 PM
ozarkgem
This may have been covered before. I always start from the small end. A friend of mine just bought a bandsaw and was told by the Amish sawmillers to start at the large end and toe board the small end up to center. They said that is what Woodmizer says to do in their manual. So have I been doing it wrong all these years? What would be the advantage to it?
drobertson
There would be less travel time to the shorts that come off the log.
It can at times cause an issue with entry cuts, but this is just my experience.   I would prefer to saw small end first, and sacrifice the time.  Just my way of doing it, not set in stone, but a foundation I try to stay near to.
ozarkgem
drobertson
In the snow belt, chigger belt, ragweed belt ;D  25 miles north of West plains,
woodyone.john
With large diameter logs I like to start at the big end,because any trimming required is easy to get done if you have to back up a tad. for smaller diameter then I prefer the small end to me so I can tell what I can/will get out of the log
cheers john
Saw millers are just carpenters with bigger bits of wood
ozarkgem
Know the area pretty well. My first wife was from Rover. Got married there. Your pretty close to Willow Springs then.
boscojmb
Quote from: ozarkgem on April 06, 2014, 08:00:17 PM
Hi,
It only matters on big logs. You don't want to get 3/4 the way through your cut and realize that there was a little bit more "butt swell" than you first thought. Now you are faced with trying to back the blade out of the cut so that you can resize the butt with a chainsaw. I always saw from the small end on all but the largest logs.
John B
John B.
Log-Master LM4
drobertson
Traveled through Rover many a times, lots of ball games in Kosh, and Thayer,   Got to watch for the deer in that neck of the woods!
Peter Drouin
I pick up the log and bring It to the mill and cut it, I don't care which way it Is, The Wood Mizer doesn't care ether. ;D
A&P saw Mill LLC.
License NH softwood grader.
lyle niemi
lyle and others,why do you start on the end you do??
lyle niemi
Quote from: thecfarm on April 06, 2014, 08:42:56 PM
When I measure the small end I know what size lumber I can make
ozarkgem
you scale from the small end so that is where the lumber starts. I have sawed from both ends but for me the small end seems to be faster. I don't have to walk down and measure the log that way. If you had a laser line then it would be better.
drobertson
Quote from: lyle niemi on April 06, 2014, 08:46:23 PM
One very good reason,  plus the sweep, determines a lot on what to expect,
Like Peter, which ever way the log rolls on the mill. Frank C.
JustinW_NZ
Quote from: woodyone.john on April 06, 2014, 08:22:25 PM
cheers john
ditto!
Gear I run;
lyle niemi
My sawing methods might be different from most, I use the small logs for the smaller lumber. I will not take a 20 inch diameter log and make 2x4s out of it, Im thinking that would be a crime
YoungStump
I'm still fairly new to sawing but I prefer to start on the small end for several reasons. It's easier for me to tell what I can make out of a log. If I start from the big end I sometimes have trouble catching the first slabs with my drag back fingers. Also I'm running a remote mill from the hitch end of the sawmill and it seems if I use my rear toeboard to level up a log I forget to lower it half the time and end up with a danG tapered cant!! But I saw some either way because I'm not the one loading the logs.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
drobertson
It needs to be said, that a cut may not be made at the bark on the small end,  just it begins at the small end.
many logs with a butt swell there is a lot of quality short boards off these short boards,  it really boils down to travel time and the quality of entry cut, and how much is allowed for cut off on some variations produced from beginning at the big end, Just my experience,    david
Corley5
I like to saw from the small end with the Corley because if I need to push an end out to make up for taper it's right there and I don't have to walk to one of the other bunks to make the adjustment.  That said I seldom sort and load the logs that way  ;) ;D
GAB
I prefer to start with the small end as I am more apt to see the toe roller up when I turn the log.
OK less apt to make long tapers.
Gerald
WoodenHead
I generally saw from the small end as well, but I don't sweat it if the log is backwards.  I will purposely saw from the large end if the log has the remote possibility of max'ing the mill.  I've had it a couple times where I started a large log from the small end only to find out the my mill wasn't quite big enough...
drobertson
This has happened a few times, :D man it kinda stinks too!  a bad ball park figure I suppose,
but it happens,
Dave Shepard
I generally start from the large end, and if cutting long timbers, always from the large end. I don't, yet, have any hydraulics on the bed extension, so I need as much weight as possible on the main bed for the turner to work. I am moving my first toe board to the bed extension, so I will have to saw big end first, or I won't be able to level it.
On smaller (normal) logs, I prefer the small end first for the reasons already stated.  On large logs that may need Bibbying, I want the large end first.
