TimberWolf TW-P1 Hydraulic valve issue
Started by Local4Fitter, April 05, 2014, 04:34:32 PM
Local4Fitter
I have a TW-P1 with auto return that doesn't work properly. When I push the handle to return the cylinder it initially starts the return stroke and will stop. It doesn't stop in the same spot all the time. I don't know what brand the valve is. In fact I don't know squat about hydraulics. What should I look for? Thanks in advance Doug
1974 John Deere 510, Wood fired pizza oven,2005 Dodge/Cummins,Firearms for all occasions.
dave_dj1
I know people have had problems with this before, some say after it warms up it's ok. Some people have had to adjust the relief one way or the other to get the detent to stay in. I'm not a 100% sure but I thought I read that they have stopped using the auto cycle valve.
dave
I just have a cheapy wood spliter. Takes mine about 10-15 minutes to warm up and work well when it is cold outside. I would give TimberWolf a call on Monday. I don't know nothing about it either.
North River Energy
Rotate the spool 180 and see if that makes a difference. With enough hours on the valve, the detent groove may have a track worn out of it allowing the detent ball to 'walk out' prematurely.
Local4Fitter
Local4Fitter
Turned the spool 180 and that did the trick. Works like it's supposed to. Thanks for the advice North River.
North River Energy
You bet.  Glad that worked out.  Thanks for the update.
skinnyest
local, was the handel kicking out or was the cylinder just stopping.I have the same splitter and sometimes(usually when its cold)the handle kick out,usually when I got my back turned grabbing the next piece.love the splitter but that's agraviting.
