3-53 help identify the year
Started by shawn55, March 31, 2014, 11:25:32 PM
shawn55
Just wondering where the serial numbers are on a 3-53 so I can identify the year.
bushmechanic
 The serial number and model number is stamped on the upper rear corner of the engine block. The numbers should start with 5033-xxxx and the serial number will be 3D-xxxx. A quick way to tell the year is check the governor housing tag as the year is usually stamped on it, unless someone changed it.
tj240
most 353 are the same the only diff is the rotation i believe
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
shawn55
