progress of my new truck
Started by Birchwood Logging, March 27, 2014, 10:01:35 PM
Birchwood Logging
John Deere 700H with winch, John Deere 550A with winch, Cat 232 Skid Steer,Cat 262c Skid Steer, Wood Mizer Lt 40 super HD, Ford F-700 and F-600 log trucks, Ford F-450 dump truck
landscraper
Looks like a money maker to me! What size tubing/wall thickness did you use for the bunks?  I need to make a set of bolt-on bunks for my tagalong trailer, I have some 4", 5" and 6" square 1/4" wall, I'm thinking I'll use the 5" for the uprights, use some 8" tall I-Beam for the sleeper and gusset the inside corner.  Looks like you plated the upright back to the open face between the flanges of the I-Beam, that looks like a good idea too.  Good luck with the new truck, sounds like a big step-up!
Firewood is energy independence on a personal scale.
Birchwood Logging
The standards or up rights is 2 pieces of 1\4 thick 4 inch c channel welded together to make a square tube. The bottom ibeams are plated and gusset's welded in them on the ones that support the standards it makes them a little more ridged
Ohio_Bill
Looks Good   . Cant wait to see a load on it .
Quote from: landscraper on March 30, 2014, 05:30:38 PM
These are bolt on,s my son in law made for me .
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
treeslayer2003
  these I made to pin on like a receiver hitch.
landscraper
Ohio_Bill and Treeslayer - thanks, that's good to look at for ideas.  I like the red ones on the flatbed, real neat job.  I want to make sure I give plenty of room between the logs and the bed for the forks, I have a Case 621D loader with some fat forks and I don't want to be banging stuff around when I am unloading my own logs so I will use the 8" IBeam to get my logs off the deck of the trailer enough that the forks can fit easily under.  I bet mine don't turn out as pretty as the ones your son-in-law made Bill, somehow my stuff always gets put to work before I break out the spray gun.
Ohio_Bill
Did your GMC get broke in this week ?
Bill
bigred1951
soo hows the truck doing. Any pics of it hauling a load
Birchwood Logging
     some low grade tie logs being loaded
treeslayer2003
Birchwood Logging
It handles a load better a lot less sway I've only drove it with a load twice hard to get use to the Detroit my truck driver seems to like it
treeslayer2003
lol, just floor board her bro.
Autocar
Bill
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Birchwood Logging
JD 450c track loader looking to buy a knuckle boom very soon
luvmexfood
Hey Birchwood. Get the longjohns back out. Calling for low 20s Tuesday night over on this side of the mountain.
Give me a new saw chain and I can find you a rock in a heartbeat.
Birchwood Logging
Hope this will be our last little cold spell
luvmexfood
You and me both. I took a part-time job in Feb working for one of the major gardening supply companies. I usually work Thur- Sat but with a big promotion going on I also worked the last two Sundays. They had a some products half price at Lowe's. Sold pallets of garden soil. At times people would be standing waiting for it and finally ran out. Took the job because I though if the spring was anything like the winter it would be mud. BTW it will be coming to Lowe's in Hazard this week. Good prices on some items.
Seems like rain almost every Mon-Wed and then turns pretty when I have to work. Was off today but the wind was really howling big time so I did not cut. Did some maintenance work. Forgot that I could go out and clean-up tree crowns that had fallen in pasture. Guess I will cut it for firewood.
