progress of my new truck
Started by Birchwood Logging, March 27, 2014, 10:01:35 PM
Birchwood Logging
John Deere 700H with winch, John Deere 550A with winch, Cat 232 Skid Steer,Cat 262c Skid Steer, Wood Mizer Lt 40 super HD, Ford F-700 and F-600 log trucks, Ford F-450 dump truck
Kemper
Birchwood Logging
treeslayer2003
now ya got a truck! air brakes, diesel......GMC? what engine?
Birchwood Logging
Yes it is a 83 gmc brigadier it has a 671 Detroit and a 10 speed trans I like my old ford better though not a big gmc fan lol
goose63
G M C great mountain climber
that knot head brother of mine says gay mans caddy  ;D
its a good looking truck
goose
thank you to all the vets
chevytaHOE5674
Autocar
Bill
tj240
the detroit and ten speed should pull alot better than the old ford plus stop better. does it have a jake brake
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
pineywoods
There's a local logger here that ran an identical setup for years. Easy to tell when it was him coming up the hill.  ;D No doubt it wasn't a cummins or cat...
Wellmud
I suspect you will find that truck will carry its load of logs and the old ford at the same time :D You cannot beat air brakes for loads that size, and I love hearing those 6-71's run :)
Woodmizer LT35 manual, Kubota L3130, Farmi 351, Stihl 029 super, 3 Logrite canthooks
bigred1951
i like it. Now all it needs is 2 big chrome straight pipe stacks thatll make it roar  8)
Birchwood Logging
If I can haul 2500 feet on it I will be happy as far as power it will have about the same as the old ford that has a reman 3208 punched out 30 over with 3 ring pistons and the injection pump cranked up its probably pushing 220 to 240 horse the Detroit is pushing around 238 it will be nice to have a few extra gears and another axel as for brakes both trucks have air brakes the GMC should stop a little better. Now all I need is a driver for the GMC
Birchwood Logging
Quote from: bigred1951 on March 28, 2014, 01:58:08 PM
lol its already so loud with one muffler stack you can hear it coming a mile away when its cranking against governor it would be nice to have it chromed
bigred1951
i say its fun to drive with a 10 speed. Only thing ive ever drove is 5 and 2 speed rear
Birchwood Logging
Its totaly different than the 5 plus 2 I'm use to you only use the clutch to take off and stop you shift the gears with out clutching that's hard for me to get use to lol especially  bringing the rpms up to down shift
treeslayer2003
I had an IH set up just like that, 2500 ft an easy load.....it will run like its empty. 10 speed .....when you get used to it you won't want to get in a 5+2 no more. remember, turn yer Detroit up....they like to turn and will shift better that way. you are on the right track here.
oh, if that 238 is tuned right it will take the lunch money from a 3208 lol.
chevytaHOE5674
I would suggest some ear plugs. My father in law ran a screaming straight piped detroit powered logging truck for years right out of highschool, now he can't hear a thing.
sawguy21
 :D Those kerosene burners need to be run on the pin to make them work. Don't try to lug them. I rode shotgun on a bull nose Kenworth with one of those equipped with a straight pipe behind the cab. Conversation stopped when the jake kicked in.
snowstorm
Quote from: Birchwood Logging on March 28, 2014, 09:28:02 PM
it will take a while to get used to it. try this when down shifting going down hill  or coming to a stop. rpm around 1500 with your left foot step on the brake not real hard while doing this apply a little fuel. this unloads the trans for just a sec so you can get it out of gear. blip the throttle you will need 1900rpm or so. you will get it. with a rt910 trans preselect  the range box. in 5th gear pull the button then shift to 6. downshifting going up hill just blip it an give her another gear. up shifting just let off it an slide it in. keep that motor wound up never lug to 1500 or lower. it it only turns 2100 under load turn it up to 2300
treeslayer2003
we had a 72' KW 900, 8v 71 dual exuast 13 speed......it would turn 2500, talk about loud lol, I could hear the old man comin back 5 miles away lol.
timberlinetree
Nice truck you gonna name her?
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Birchwood Logging
I'm gonna have to see how it performs first and let it earn it name accordingly. Got the bed all finished up this weekend hope to be hauling this week
cutter88
you got that right bud no trucks a truck until shes got a set of straight pipes :)
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
Birchwood Logging
Finally got the bed finished
